查看: 3646|回复: 2
[求助] 有了解ARM-China STAR 的吗
发表于 2019-12-3 14:15:50 | 显示全部楼层 |阅读模式
    最近在研究ARM-China发布的STAR-CPU,关于TCM章节有点不是很理解,AHBT是外部访问TCM的AHB-slave总线,一般来说是DMA,这里introduce dependency是什么意思?    The processor does not support AHBT transactions that are directly dependent on software memory transactions. This means that the system must not introduce any dependencies where a software memory access cannot complete until a corresponding AHBT transaction completes .    Loopback from processor master ports on to the AHBT are not supported because this might cause deadlock (Loopback arrangements should not be required. The processor has higher bandwidth to TCM than the AHBT interface .This means directly transferring data to and from TCM should be faster than through the AHBT interface )
    This restriction does not preclude arrangements where software memory-mapped accesses are used . On the S-AHB for example, to request an external agent to perform transactions on the AHBT interface. In this case do not introduce dependency in the system between the control access that initiates the transaction and the transaction itself.
发表于 2020-6-2 11:05:59 | 显示全部楼层
正在了解中,看介绍说keil v5.30 支持 device based ARM china star core,但没找到相关器件;请问楼主用的是那个版本keil ,或者那些器件是基于arm china star core的
 楼主| 发表于 2021-12-3 09:06:38 | 显示全部楼层
gushenglin 发表于 2020-6-2 11:05
正在了解中,看介绍说keil v5.30 支持 device based ARM china star core,但没找到相关器件;请问楼主用的 ...
用M7的CMSIS改的临时的
GMT+8, 2025-9-16 03:00 , Processed in 0.011239 second(s), 3 queries , Gzip On, Redis On.
