查看: 4603|回复: 6
Cadence 5141仿真出现问题(已解决)
发表于 2019-10-19 10:15:51 | 显示全部楼层 |阅读模式
save & check →ADE environment→analysis→run and simulation 然后CIW中出现下面错误
*Error* Errors encountered during simulation.The simulator run log has not been generated.
    possible cause could be an invalid command line option for the version of the simulator you are running .Choose Setup -> Environment
    and verify that the command line options specified in the userCmdLineoption field are supported for the simulator.
A lternatively , run the simulator standalone using the runSimulation file in the netlist directory to know the exact cause of the error."
运行runsimulation 后提示line1:spectre : command not found
求大佬帮忙解答
发表于 2019-10-19 17:01:24 | 显示全部楼层
Everything is simple.
The spectre command is not in the $PATH for executable files.
What returns "which spectre" command in the terminal window?
If she does not give the PATH to the spectre command.
Then you did not install MMSIM/SPECTRE.
Or you did not set the $PATH variable correctly for spectre.
 楼主| 发表于 2019-10-19 19:45:04 | 显示全部楼层
thanks , i m new in cadence
linux prompt  returns "spectre :command not found"
then how to install spectre/MMSIM or set the $PATH variable
there are Cadence IC5141 and IC61 in my server
发表于 2019-10-20 18:28:32 | 显示全部楼层
Just find MMSIM13 for for IC5141
or SPECTRE for IC6
and install it.
 楼主| 发表于 2019-10-22 20:32:11 | 显示全部楼层
or SPECTRE for IC6
and install it.
thanks a lot
I have solved this problem according to your advice
发表于 2022-4-18 10:34:04 | 显示全部楼层
咋解决的呢? 我也遇到了这个问题,求解答
发表于 2023-11-16 03:10:17 | 显示全部楼层
or SPECTRE for IC6
and install it.
thanks
GMT+8, 2025-12-30 03:37 , Processed in 0.019771 second(s), 3 queries , Gzip On, Redis On.
