查看: 2789|回复: 9
[资料] How unmatched impedance at the clock input of an RF ADC affects SNR and jitter
发表于 2019-8-30 15:11:47 | 显示全部楼层 |阅读模式
Modern high-speed data acquisition systems,such as phased-array radars or high-speed digitizers, continue to push higher both the bandwidth and input-frequency requirementsn without any sacrifice of dynamic range performance. System designers need to deliver the highest possible signal-to-noise ratio (SNR) in order to optimize system performance down to a tenth of a decibel. However, it is well known that as input frequencies increase, the analog-to-digital converter (ADC) SNR becomes increasingly sensitive to the sampling-clock’s timing uncertainty— or jitter. This applies to slower speed but high-precision ADCs with 16-bit resolution or more, and very high SNR. This situation also applies to high-speed 12- and 14-bit
ADCs that have a wide bandwidth front-end
to sample signals at multiple gigahertz. The
SNR degradation follows a well known formula of:
SNR = 20log(2π × fIN × tJitter),
where tJitter is the combination of both external and internal
aperture jitter. Figure 1 shows SNR dependency on the
input frequency and the total amount of clock jitter for an
ADC with 76-dB thermal noise
How unmatched impedance at the clock input of an RF ADC affects SNR and jitter.pdf
2.14 MB, 下载次数: 89 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2019-8-30 21:20:09 | 显示全部楼层
thanks
发表于 2019-9-23 15:50:31 | 显示全部楼层
thanks
发表于 2019-9-23 18:08:19 | 显示全部楼层
谢谢
发表于 2019-9-24 09:30:09 | 显示全部楼层
感谢分享!!!
发表于 2019-9-24 18:28:55 | 显示全部楼层
发表于 2019-9-24 23:28:24 | 显示全部楼层
Thanks sharing.
TI application note
发表于 2019-9-25 09:11:14 | 显示全部楼层
谢谢
发表于 2023-6-26 15:57:38 | 显示全部楼层
谢谢
发表于 2023-6-26 16:29:58 | 显示全部楼层
谢谢分享
GMT+8, 2025-12-21 01:07 , Processed in 0.023151 second(s), 3 queries , Gzip On, Redis On.
