查看: 2275|回复: 0
[资料] 转换IC/信号转换芯片NCS8801S:RGB/LVDS-to-eDP(RGB转edp)
发表于 2019-8-8 11:36:56 | 显示全部楼层 |阅读模式
**型号**:NCS8801S
**产品特点**:低功耗,抗干扰能力强
**输入**:Single/Dual link LVDS/RGB
**输出**:EDP
**封装**:QFN56  (7mm x 7mm)
**最大分辨率**:2560*1600
eDP输出:**eDP Output**:
1/2/4-lane eDP @ 1.62/2.7Gbps per lane
FHD to WQXGA (2560*1600) supported
RGB输入:**RGB Input**
18/24bit RGB Interface
Pixel clock up to 270MHz
Pin order reversal supported
LVDS输入:**LVDS Input**
Single/Dual-channel 6/8bit LVDS (Sync) interface
400Mbps to 1Gbps per data pair
Channel and polarity swap supported
参考时钟:**Reference Clock**
Any freq. between 19MHz and 100MHz
Crystal or single-ended clock input
Built-in 5000ppm SSC generator
其它:**Misc**
I2C/SPI for chip configuration
Built-in eDP handshake protocol
I2C-AUX channel for TCON/DPCD/EDID
control
Built-in video test pattern
功率:**Power**
1.2V core supply
2.5V or 3.3V IO supply
RGB IO can go down to 1.8V
Power consumption ~ 150mW
@ 2048*1536*24bit*60Hz, LVDS mode
Deep-sleep mode power <1mW
封装**Package**
QFN-56 (7mm x 7mm) package
RoHS Compliant
NCS8801S_DS_V0p93.pdf
1.33 MB, 下载次数: 14 , 下载积分: 资产 -2 信元, 下载支出 2 信元
8801S规格书
GMT+8, 2025-12-11 18:23 , Processed in 0.012576 second(s), 6 queries , Gzip On, Redis On.
