楼主: deepcore
一個非常詳細的Pipeline ADC博士論文
发表于 2008-2-26 19:35:41 | 显示全部楼层
Traditional calibration methods for pipelined Analog-to-Digital Converters (ADC) cannot always generate acceptable results in modern sub-micron integrated circuit processes because of a downward trend in power supply voltage. The reduced headroom between maximum signal voltage and low power supply voltage rails causes amplifier non-linearity. This in turn may cause the corrected digital output to be non-monotonic. We present a modified calibration approach called Correction Factor at Actual Transition (CFAT) that always produces monotonic results. However, both the traditional and the CFAT approach produce limited improvement in integral non-linearity (INL) and effective number of bits (ENOB). We, therefore, present a second approach called True N Bit (TNB) calibration. With TNB, we insure a monotonic output, less than ½ LSB INL, and ENOB less than ½ LSB from the ADC’s theoretical resolution. These achievements are made with a full signal swing of 150mV from either rail of the 1.8V power supply.
发表于 2008-2-26 20:21:08 | 显示全部楼层
kankan
发表于 2008-2-26 20:49:14 | 显示全部楼层
hao man
发表于 2008-2-26 21:48:39 | 显示全部楼层
Thanks very much.
发表于 2008-3-5 00:46:11 | 显示全部楼层
多谢分享.
发表于 2008-3-5 09:01:03 | 显示全部楼层
来去看了!
感谢啦!
发表于 2008-3-17 17:13:59 | 显示全部楼层
ddddddddddd
dddddddddddddd
发表于 2008-3-18 11:30:23 | 显示全部楼层
thanks a lot, it is very useful for me,
发表于 2008-3-18 11:54:57 | 显示全部楼层
Thanks
发表于 2008-3-20 22:08:49 | 显示全部楼层
:lol :lol :lol :lol :lol
GMT+8, 2025-11-10 15:49 , Processed in 0.034805 second(s), 3 queries , Gzip On, Redis On.
