查看: 2522|回复: 3
An error when runing Snps 2019.06 Tools
发表于 2019-7-7 18:04:00 | 显示全部楼层 |阅读模式
There is a new tool in this BBS:
custom_wv_adv_vP-2019.06
But got an Error:
[SCL] Error:  One possible reason for this error is that FLEXlm version of the application is higher than the license daemon version. If this is the case, please upgrade the license daemon to latest version (SCL-602)
How can I solve this issue?
Thanks!
发表于 2019-7-8 06:11:15 | 显示全部楼层
安装ScI2018.06,但2019的LiC格式变了,不知方法呢
发表于 2019-7-8 07:12:30 来自手机 | 显示全部楼层
Use the version scl-2018.06!
发表于 2019-7-8 07:13:15 来自手机 | 显示全部楼层
GMT+8, 2025-12-29 01:46 , Processed in 0.013622 second(s), 4 queries , Gzip On, Redis On.
