查看: 5233|回复: 4
Xcelium 编译xilinx库错误
发表于 2019-5-12 11:31:53 | 显示全部楼层 |阅读模式
编译库的时候发现serdes的加密文件编译过不去
换成ies 和vcs就不会报错了。大家有遇到过这个问题么?
file: /home/soft/Xilinx/Vivado/2018.3/data/secureip/gthe3_channel/gthe3_channel_001.vp
xmvlog: *F,INTERR: INTERNAL EXCEPTION
The tool has encountered an unexpected condition and must exit.
Contact Cadence Design Systems customer support about this
problem and provide enough information to help us reproduce it,
including the logfile that contains this error message.
  TOOL:        xmvlog(64)        18.03-s001
  HOSTNAME: roc.nb.centos7
  OPERATING SYSTEM: Linux 3.10.0-957.12.1.el7.x86_64 #1 SMP Mon Apr 29 14:59:59 UTC 2019 x86_64
  MESSAGE: dt_get_known_datatype hit unknown datatype
csi-xmvlog - CSI: Cadence Support Investigation, sending details to /home/roc/xmvlog_28733.err
csi-xmvlog - CSI: investigation complete, send /home/roc/xmvlog_28733.err to Cadence Support
xmvlog(64): 18.03-s001: (c) Copyright 1995-2018 Cadence Design Systems, Inc.
csi-xmvlog - CSI: Command line:
/home/soft/cadence/XCELIUM1803/tools/bin/64bit/xmvlog
    -MESSAGES
    -NOLOG
    -CDSLIB cds.lib
    -HDLVAR hdl.var
    -work secureip
    -f /home/roc/xil_simlib/xcelium_2018.3/secureip/.cxl.verilog.secureip.secureip.lin64.cmf
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/hbm_one_stack_intf/hbm_one_stack_intf_001.sv
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/hbm_two_stack_intf/hbm_two_stack_intf_001.sv
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/gthe2_channel_fast/gthe2_channel_fast_001.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/gthe2_channel_fast/gthe2_channel_fast_002.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/gtxe2_channel_fast/gtxe2_channel_fast_001.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/gtxe2_channel_fast/gtxe2_channel_fast_002.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/gtxe2_channel/gtxe2_channel_001.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/gtxe2_channel/gtxe2_channel_002.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/gtxe2_common/gtxe2_common_001.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/gtxe2_common/gtxe2_common_002.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/pcie_2_1/pcie_2_1_001.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/pcie_2_1/pcie_2_1_002.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/iserdese2/iserdese2_001.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/iserdese2/iserdese2_002.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/oserdese2/oserdese2_001.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/oserdese2/oserdese2_002.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/in_fifo/in_fifo_001.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/in_fifo/in_fifo_002.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/out_fifo/out_fifo_001.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/out_fifo/out_fifo_002.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/phy_control/phy_control_001.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/phy_control/phy_control_002.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/phaser_in/phaser_in_001.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/phaser_in/phaser_in_002.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/phaser_out/phaser_out_001.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/phaser_out/phaser_out_002.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/gthe2_channel/gthe2_channel_001.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/gthe2_channel/gthe2_channel_002.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/gthe2_common/gthe2_common_001.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/gthe2_common/gthe2_common_002.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/pcie_3_0/pcie_3_0_001.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/pcie_3_0/pcie_3_0_002.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/gtpe2_channel/gtpe2_channel_001.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/gtpe2_channel/gtpe2_channel_002.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/gtpe2_common/gtpe2_common_001.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/gtpe2_common/gtpe2_common_002.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/gthe3_channel/gthe3_channel_002.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/gthe3_common/gthe3_common_002.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/gthe3_common/gthe3_common_001.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/gtye3_channel/gtye3_channel_002.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/gtye3_channel/gtye3_channel_001.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/gtye3_common/gtye3_common_002.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/gtye3_common/gtye3_common_001.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/iserdese3/iserdese3_001.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/iserdese3/iserdese3_002.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/oserdese3_k2/oserdese3_k2_001.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/oserdese3_k2/oserdese3_k2_002.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/rxtx_bitslice_k2/rxtx_bitslice_k2_001.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/rxtx_bitslice_k2/rxtx_bitslice_k2_002.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/rx_bitslice_k2/rx_bitslice_k2_001.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/rx_bitslice_k2/rx_bitslice_k2_002.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/tx_bitslice_k2/tx_bitslice_k2_001.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/tx_bitslice_k2/tx_bitslice_k2_002.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/tx_bitslice_tri_k2/tx_bitslice_tri_k2_001.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/tx_bitslice_tri_k2/tx_bitslice_tri_k2_002.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/bitslice_control_k2/bitslice_control_k2_001.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/bitslice_control_k2/bitslice_control_k2_002.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/iserdese3_d1/iserdese3_d1_001.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/iserdese3_d1/iserdese3_d1_002.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/oserdese3_d1/oserdese3_d1_001.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/oserdese3_d1/oserdese3_d1_002.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/rxtx_bitslice_d1/rxtx_bitslice_d1_001.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/rxtx_bitslice_d1/rxtx_bitslice_d1_002.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/rx_bitslice_d1/rx_bitslice_d1_001.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/rx_bitslice_d1/rx_bitslice_d1_002.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/tx_bitslice_d1/tx_bitslice_d1_001.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/tx_bitslice_d1/tx_bitslice_d1_002.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/tx_bitslice_tri_d1/tx_bitslice_tri_d1_001.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/tx_bitslice_tri_d1/tx_bitslice_tri_d1_002.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/bitslice_control_d1/bitslice_control_d1_001.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/bitslice_control_d1/bitslice_control_d1_002.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/pcie_3_1/pcie_3_1_001.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/pcie_3_1/pcie_3_1_002.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/cmac/cmac_001.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/cmac/cmac_002.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/cmac_es2/cmac_es2_001.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/cmac_es2/cmac_es2_002.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/ilkn/ilkn_001.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/ilkn/ilkn_002.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/ilkn_es2/ilkn_es2_001.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/ilkn_es2/ilkn_es2_002.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/cmace4/cmace4_001.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/cmace4/cmace4_002.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/gthe4_channel/gthe4_channel_002.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/gthe4_channel/gthe4_channel_001.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/gthe4_common/gthe4_common_001.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/gthe4_common/gthe4_common_002.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/gtye4_channel/gtye4_channel_002.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/gtye4_channel/gtye4_channel_001.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/gtye4_common/gtye4_common_002.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/gtye4_common/gtye4_common_001.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/ilkne4/ilkne4_001.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/ilkne4/ilkne4_002.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/pcie40e4/pcie40e4_001.vp
        /home/soft/Xilinx/Vivado/2018.3/data/secureip/pcie40e4/pcie40e4_002.vp
csi-xmvlog - CSI: *F,INTERR: INTERNAL EXCEPTION
csi-xmvlog - CSI: Cadence Support Investigation, recording details
Verilog Syntax Tree: module declaration (VST_D_MODULE)
        File: /home/soft/Xilinx/Vivado/2018.3/data/secureip/gthe3_channel/gthe3_channel_001.vp, line 29, position 23
        Scope: SIP_GTHE3_CHANNEL
        Decompile: SIP_GTHE3_CHANNEL#(SIM_RECEIVER_DETECT_PASS,SIM_RESET_SPEEDUP,SIM_TX_EIDLE_DRIVE_LEVEL,SIM_VERSION,clock_delay,data_delay,enable_delay,reset_delay,setreset_delay)
        Source  : module SIP_GTHE3_CHANNEL #(
        Position:                        ^
Verilog Syntax Tree: always statement declaration (VST_D_ALWAYS_STMT)
Verilog Syntax Tree: item dag (VST_DAG_ITEM)
        Decompile: unable to decompile type 910
Verilog Syntax Tree: parameter definition declaration (VST_D_DEFPARAM)
        Decompile: unable to decompile type 538
Verilog Syntax Tree: indexed vector type (VST_T_INDEXED_VEC)
        Decompile: integer
Verilog Syntax Tree: sequential block statement (VST_S_SEQ_BLOCK)
Verilog Syntax Tree: register declaration (VST_D_REG)
        Decompile: reg veam_drp_push
Verilog Syntax Tree: event or expression (VST_E_EVENT_OR)
        Decompile: BUT.Ichannelfull.veam.gen_mc_tco_comlgcfg0 or veam_drp_push
Verilog Syntax Tree: nonblocking assignment statement (VST_S_NONBLOCKING_ASSIGNMENT)
Verilog Syntax Tree: event control expression (VST_E_EVENT_CONTROL)
        Decompile: @<>
Verilog Syntax Tree: concatenation expression (VST_E_CONCATENATION)
        Decompile: {BUT.Idrpchdual.Idrp_top2.Idrp0.I4.I1.I3.Imc_vdd.mcell[15],BUT.Idrpchdual.Idrp_top2.Idrp0.I4.I1.I3.Imc_vdd.mcell[14],BUT.Idrpchdual.Idrp_top2.Idrp0.I4.I1.I3.Imc_vdd.mcell[13],BUT.Idrpchdual.Idrp_top2.Idrp0.I4.I1.I3.Imc_vdd.mcell[12],BUT.Idrpchdual.Idrp_to
Verilog Syntax Tree: hierarchical reference declaration (VST_D_OOMR)
        Decompile: BUT.Idrpchdual.Idrp_top2.Idrp0.I4.I1.I3.Imc_vdd.mcell
Verilog Syntax Tree: bit select expression (VST_E_BIT_SELECT)
        Decompile: BUT.Idrpchdual.Idrp_top2.Idrp0.I4.I1.I3.Imc_vdd.mcell[0]
Verilog Syntax Tree: logic type (VST_T_LOGIC)
        Decompile: reg
Verilog Syntax Tree: number expression (VST_E_NUMBER)
        Decompile: 0
Verilog Syntax Tree: hierarchical reference type (VST_T_OOMR)
Verilog Syntax Tree: name component oomr (VST_OOMR_NAME_COMPONENT)
Intermediate File: root (IF_ROOT)
Intermediate File: string (IF_STRING)
csi-xmvlog - CSI: investigation complete took 0.018 secs, send this file to Cadence Support
发表于 2019-7-1 18:49:46 | 显示全部楼层
Xcelium_Incubation_General 1.0 - Failed
发表于 2019-7-20 07:03:54 | 显示全部楼层
Can anyone share XCELIUMMAIN_18.03.001 instalation packages..?
 楼主| 发表于 2019-7-25 09:14:01 | 显示全部楼层
是license问题?
发表于 2025-4-22 13:47:27 | 显示全部楼层
我也遇到了相同的问题
大家解决了么?
GMT+8, 2025-12-28 11:45 , Processed in 0.015294 second(s), 3 queries , Gzip On, Redis On.
