查看: 3301|回复: 0
请教Silvaco2016 安装SFLM 主机不能解析的问题
发表于 2019-1-27 19:16:23 | 显示全部楼层 |阅读模式
跟各位高手请教一下,在REDHAT 6.5 的64位下安装Silvaco 2016 时遇到主机不能解析的问题。
不知道问题出在哪里,该怎么解决,谢谢。
[root@fierro silvaco]# sudo /opt/silvaco/bin/sflm -i
Version of rpc.sflmserverd : 8.2.12.R
Version of sflm_monitord : 7.4.16.R
Setting SFLM administrative password.
New Password    ?
Retype password ?
License server password set.
aksusbd version   1.14 (#7528) - key API (USB) version: 3.88
aksusbd version         - (parallel driver not available)
Running s_install version: 2.0.3.R  please wait...
Terminating SFLM RPC servers ... done.
Currently 14793756 KB free in /tmp (>= 8000)
Preparing to install the SFLM server daemon.
This procedure will modify or create the following system files:
        /etc/rc.d/init.d/sflm
Backups will be created in /var/tmp/s_install.bak
before any files are modified.
Run '/opt/silvaco/etc/s_install -rm-bak' or
'/var/tmp/s_install.bak/remove' to remove backup files.
Do you wish to proceed? [y|n] y
Verifying permissions ... done.
Installing servers in init.d ...
Backing up /etc/rc.d/init.d/sflm to /var/tmp/s_install.bak/bak.sflm~1~ ... done.
Installation done.
Starting and verifying servers ...
SFLM using license file: /var/opt/sflm/licenses
SFLM server ready.
rpcinfo: fierro: Temporary failure in name resolution
Verification failed for sflm on host fierro.
RPC server verification failed.
GMT+8, 2025-12-29 12:58 , Processed in 0.011741 second(s), 4 queries , Gzip On, Redis On.
