查看: 3149|回复: 4
[资料] BCM53128 -Multiport Gigabit Ethernet Switches
发表于 2018-11-21 20:31:22 | 显示全部楼层 |阅读模式
The Broadcom® BCM53128 is a highly integrated,cost-effective unmanaged-smart gigabit switch. The switch design is based on the field-proven, industryleading ROBO architecture. This device combines all the functions of a high-speed switch system including packet buffers, PHY transceivers, media access controllers (MACs), address management, port-based rate control, and a non-blocking switch fabric into a single 65-nm CMOS device. Designed to be fully compliant with the IEEE 802.3™ and IEEE 802.3x specifications, including the MACcontrol
PAUSE frame, the BCM53128 provides compatibility with all industry-standard Ethernet, 53128-DS07-R.pdf (2.62 MB , 下载次数: 69 ) Fast Ethernet, and Gigabit Ethernet (GbE) devices.
发表于 2018-11-22 08:27:43 | 显示全部楼层
多谢分享
发表于 2018-11-22 22:55:00 | 显示全部楼层
thanks
发表于 2019-1-6 17:32:40 | 显示全部楼层
gooood
发表于 2020-2-6 10:40:43 | 显示全部楼层
thanks for sharing
GMT+8, 2025-12-23 08:53 , Processed in 0.014338 second(s), 3 queries , Gzip On, Redis On.
