查看: 4707|回复: 11
[资料] Debug Automation from Pre-Silicon to Post-Silicon
发表于 2018-11-11 22:25:09 | 显示全部楼层 |阅读模式
Preface
The application of Very Large Scale Integration (VLSI) circuits is ubiquitous while
the size of the hardware components is shrinking. VLSI circuits are used for a wide
range of different applications in embedded systems such as medical electronics,
automotive systems and avionics. A failure of a chip in non-critical applications
may cause significant economic loss while in critical applications may also endanger
human’s lives in the worst case. Consequently, the correct design of VLSI circuits
is crucial.
The debugging process is dedicated to localize and to rectify the root cause of the
erroneous behavior of VLSI circuits. This process often remains as a manual task
and increases the time required for development cycles of Integrated Circuits (ICs)
significantly. Therefore, debug automation procedures are required to accelerate
finding and fixing bugs and faults and, consequently, to increase the productivity
of IC design.
This book contributes to debugging and diagnosis technology at the most
challenging gaps on different abstraction levels of a hardware system, i.e., chip,
gate-level, Register Transfer Level (RTL) and transaction-level.
In this book, we propose automated debugging approaches for the bugs and
the faults which appear in different abstraction levels of a hardware system, i.e.,
transaction-level, RTL, and gate-level. Our automated debug approaches are applied
to a hardware system at different granularities to find the possible location of bugs
and faults. The transaction-based debug approach is applied to a hardware system at
transaction-level asserting the correct relation of transactions. Our automated debug
approach for design bugs finds the potential fault candidates at RTL and gate-level
of a circuit. In this case, logic bugs and synchronization bugs are considered as they
are the most difficult bugs to be localized. For electrical faults and, in particular,
delay faults our proposed debug automation finds the potential failing speedpaths in
a circuit at gate-level.
The proposed debug approaches for transactions, design bugs and electrical faults
have been evaluated on suitable benchmarks at different levels of abstraction, i.e.,
transaction-level, RTL and gate-level. The experiments have shown that our debug
approaches achieve high diagnosis accuracy and reduce the debugging time. As a
result, the time of the IC development cycle decreases and the productivity of IC
design increases.
We would like to thank all our coauthors for the fruitful collaboration. In
particular, we would like to thank Dr. André Sülflow for the constructive discussions
and his support during our work on this book and the underlying techniques. We are
grateful to Prof. Kaushik Roy and Prof. Anand Raghunathan for their collaboration,
important discussions, and comments. We would like to thank the German Research
Foundation (DFG) for funding our work.
Debug Automation from Pre-Silicon to Post-Silicon.pdf (4.38 MB , 下载次数: 74 )
发表于 2018-11-12 22:13:55 | 显示全部楼层
此帖仅作者可见
发表于 2018-11-13 09:12:04 | 显示全部楼层
此帖仅作者可见
发表于 2018-11-16 19:43:05 | 显示全部楼层
此帖仅作者可见
发表于 2018-11-29 13:14:25 | 显示全部楼层
此帖仅作者可见
发表于 2018-11-30 14:18:36 | 显示全部楼层
此帖仅作者可见
发表于 2018-12-4 10:47:38 | 显示全部楼层
此帖仅作者可见
发表于 2018-12-18 12:22:26 | 显示全部楼层
此帖仅作者可见
发表于 2019-7-18 18:53:21 | 显示全部楼层
此帖仅作者可见
发表于 2022-5-24 12:05:06 | 显示全部楼层
此帖仅作者可见
GMT+8, 2025-12-26 13:04 , Processed in 0.018755 second(s), 4 queries , Gzip On, Redis On.
