查看: 3242|回复: 1
[求助] 求助如何让Hspice输出所有参数值
发表于 2018-10-18 21:49:46 | 显示全部楼层 |阅读模式
各位大神:
      Hspice仿真时,有些参数是 编公式用其他已赋值参数运算得到的;想检查这些参数的运算结果,有方法让Hspice输出所有参数值吗?
发表于 2018-10-23 09:37:20 | 显示全部楼层
试试
.OPTION LIST
Prints a list of netlist elements, node connections, and values for components, voltage and current sources, parameters, and more.
Syntax
.OPTION LIST=0|1|2|3
Default
Value if option is not specified in the netlist: 0
Value if option name is specified without a corresponding value: 1
Description
Use this option as follows:
Value
Alias
Description
0
NONE
None of below supported
1
ALL
Print circuit element summary table and parameter definitions
2
ELEMENT
Print circuit element summary table only
3
PARAMETER
Print circuit parameter definitions only
The LIST option also prints effective sizes of elements and key values.
GMT+8, 2025-9-18 04:25 , Processed in 0.013572 second(s), 3 queries , Gzip On, Redis On.
