查看: 3645|回复: 4
求助[Library compiler M-2016.12 启动报错
发表于 2018-9-11 21:53:07 | 显示全部楼层 |阅读模式
输入lc_shell, 报如下的错误信息:                             Library Compiler (TM)
                                 DesignWare (R)
                 Version M-2016.12 for linux64 - Nov 15, 2016
                    Copyright (c) 1988 - 2016 Synopsys, Inc.
   This software and the associated documentation are proprietary to Synopsys,
Inc. This software may only be used in accordance with the terms and conditions
of a written license agreement with Synopsys, Inc. All other use, reproduction,
            or distribution of this software is strictly prohibited.
Error: unknown command 'set_check_library_options' (CMD-005)
Initializing...
lc_shell>
请问这个是什么原因导致的?
另外问个问题,这个的环境设置有特别要求吗?和Syno的一致吗
发表于 2019-7-9 16:28:06 | 显示全部楼层
楼主这个问题有解决吗?
发表于 2019-8-1 11:11:05 | 显示全部楼层
楼主问题解决了吗?
发表于 2020-9-14 15:44:17 | 显示全部楼层
我也遇到这个问题,没解决!求大神
发表于 2022-1-7 10:26:37 | 显示全部楼层
能分享下 Library Compiler M-2016.12么
GMT+8, 2025-9-18 02:59 , Processed in 0.013096 second(s), 3 queries , Gzip On, Redis On.
