查看: 12127|回复: 17
spectre仿真MOS管模型出parameter问题
发表于 2018-8-23 15:19:43 | 显示全部楼层 |阅读模式
在进行spectre仿真,所引用的n50,p50mos管模型无法开始仿真,错误如附件,求大神帮助
新建文本文档 (2).txt
16.23 KB, 下载次数: 134 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2018-8-24 03:00:24 | 显示全部楼层
Please check for you model.scs file, looks like a corner definition error.
Some model parameters are defined twice.
ERROR (SFE-1999): "/opt/SMIC_018_MMRF/models/spectre/ms018g_v1p16.mdl" 435: Model `n50': parameter `toxe': Cannot run the simulation because an unknown parameter `dtoxe_n50' has been specified in expression `1.252e-08+dtoxe_n50'. Correct the expression and rerun the simulation.
发表于 2018-8-24 08:57:03 | 显示全部楼层
参数问题一般都是仿真工具版本不符合要求。看看手册对仿真器的要求。
 楼主| 发表于 2018-8-27 14:08:20 | 显示全部楼层
回复 2# jasonxzy
   this is p50 parameter*               general model parameters
+tnom    = 25              toxe    = '1.279e-008+dtoxe_p50'      dtox    = 2.15e-011       epsrox  = 3.9
+toxref  = 1.279e-008      wint    = 0               lint    = 1e-008          ll      = 1.6231e-014
+wl      = 0               lln     = 1               wln     = 1               lw      = 0
+ww      = -1.35e-014      lwn     = 1               wwn     = 1               lwl     = 0
+wwl     = 0               llc     = 0               wlc     = 0               lwc     = 0
+wwc     = 0               lwlc    = 0               wwlc    = 0               xl      = '-1.32e-008+dxl_p50'
+xw      = '1.58e-008+dxw_p50'       dlc     = 8.0158e-008     dwc     = 0               dlcig   = 0
+xpart   = 0
+xw      = '1.58e-008+dxw_p50'   looks like  X=C+dX,could i understand like this? or , can delete dxw_p50?  then the parameter become a number.will it have the same effect?
发表于 2021-1-7 23:32:28 | 显示全部楼层
我也遇到了类似的问题,请问,你解决了吗?是如何解决的?
发表于 2021-1-9 23:58:19 | 显示全部楼层
我也遇到了这种问题,请问解决了吗
回复 支持 0 反对 1
发表于 2021-5-7 15:09:30 | 显示全部楼层
顶一下,有人解决这个问题了吗
发表于 2021-6-23 22:02:23 | 显示全部楼层
我也遇到了这个问题,请问怎么解决的
发表于 2022-6-7 22:47:24 | 显示全部楼层
顶一下 同问 诸位
发表于 2022-6-8 09:45:19 | 显示全部楼层
应该是少加了一个文件,smic18mmrf加载的是*.lib文件,是不是加成*.mdl了?
GMT+8, 2025-12-20 15:19 , Processed in 0.024182 second(s), 6 queries , Gzip On, Redis On.
