查看: 4317|回复: 2
[求助] 帮忙看看ERROR(ADE-3036)
发表于 2018-8-22 14:57:19 | 显示全部楼层 |阅读模式
问题如下:
ERROR (ADE-3036): Errors encountered during simulation. The simulator run log has not been generated.
        Possible cause could be an invalid command line option for the version of the simulator
        you are running. Choose Setup->Environment and verify that the command line options
        specified in the userCmdLineOption field are supported for the simulator.
        Alternatively, run the simulator standalone using the runSimulation file in the netlist
        directory to know the exact cause of the error.
已经试了论坛上的各种解决办法,均无效,还是出现这个错误,还请大神指教!!!
发表于 2018-8-23 20:24:26 | 显示全部楼层
似乎error叙述的挺详细的了,有否按照提示检查仿真软件版本或者检查有否与仿真软件不支持的命令行选项,或者单独用命令行的方式跑仿真试试?你选的什么仿真软件
 楼主| 发表于 2018-9-6 10:06:44 | 显示全部楼层
回复 2# sea11038
   重装了一遍,这个问题就没有出现了
GMT+8, 2025-12-17 06:58 , Processed in 0.012763 second(s), 4 queries , Gzip On, Redis On.
