简历请投递至 3114835608@qq.com
以下岗位有效期一个月 招到即关
Title: Principal / Physical Design Engineer (数字后端设计Research方向)
Position Description:
• Co-work with the R&D RTL design team for IP architecture exploration and optimization of the design and constraint
• Co-work with other functional teams (Design/STA/Analog/Package/Verification) to optimize the high speed PHY IP development flow and set proper signoff criteria.
• Optimize the physical implementation methodology and flow to meet the tight timing/power target of next generation high speed PHY IP.
• Set and optimize the high speed PHY IP physical implementation guide which will be used by customers and internal global physical implementation teams.
• Perform physical design implementation tasks including floor planning, place & route, clock tree synthesis and Timing/PV/Power/Signal-EM/CLP/DFM signoff checks for some critical milestone projects.
Position Requirements:
• BS degree with 5~10+ years of applicable experience, MS degree with 4~8+ years of applicable experience in electrical engineering, microelectronics.
• Experienced with ASIC design flow, hierarchical physical design strategies, and methodologies and understand deep sub-micron technology issues.
• Solid knowledge on LP Design, static timing analysis, EM/IR-Drop/crosstalk analysis, physical verification, DFM.
• Successful track records of taping out complex, 16nm/10nm/7nm chips.
• Automation and programming-minded, solid coding experience in Makefile /Tcl/Tk/Perl.
• Innovative, self-motivated, able to work independently or as a team player.
• Excellent verbal and written communication skills in English.
Title: Lead Physical Design Engineer (数字后端设计项目方向)
• Perform physical design implementation, including floor planning, power grid design, place and route, clock tree synthesis, timing closure, power/signal integrity signoff, physical verification (DRC/LVS/Antenna), EM/IR signoff, DFM Closure.
• The candidate will have the opportunity to work on many varieties of challenging designs, i.e. low power and high speed design. The responsibility includes participating in or leading next generation PHY IP physical design, methodology and flow development.
• BS degree with 5+ years of applicable experience, MS degree with 3+ years of applicable experience in electrical engineering, microelectronics.
• Successful track records of taping out complex, 16nm/10nm/7nm chips. Automation and programming-minded, solid coding experience in Makefile/Tcl/Tk/Perl.
• Self-motivated, able to work independently or as a team player, excellent verbal and written communication skills in English.
Title: Principal / Lead Verification Engineer (数字前端验证)
Deliver/implement advanced verification solutions by utilizing Cadence’s Incisive Verification product portfolio. The engineer should be able to act as a strong team member and contributor, leading team projects and initiatives. Exercise judgment within generally defined practices and policies.
• Specific duties include:
• Deep understanding on ASIC design and verification flow
• Excellent knowledge of advanced verification methodology like eRM/OVM/UVM/VMM
• Familiar with Cadence’s Incisive Plan to Closure Methodology (IPCM)
• Proficiency in System Verilog, System C and/or e (Specman)
• Developing and using Verification Components (eVC, OVC,UVC,VIP)
• Developing and using assertion based verification and formal analysis methods
• Skilled in scripting language, such as Perl, C shell, Python, Makefile
• Assessing the project verification requirements
Essential Qualifications:
• BS degree with 3+ years of applicable experience, MS degree with1+ years of applicable experience in electrical engineering, microelectronics, comparable engineering science or solid state physics.
• Essential that the individual demonstrates strong communication, verbal and written. Requires good communication skills in English.
Desirable Qualifications:
• Will have demonstrated hands-on experience and expertise with Cadence verification design tools or equivalent tools, flows and methodologies required to execute a verification project.
• Will have demonstrated successful completion of 3+ verification projects as an individual contributor
• Will have DDR project verification experience
Principal / Lead Front-end Design Engineer (RTL) (数字前端设计)
• Deliver/implement DDR/HBM IP. The engineer should be able to act as a strong team member and contributor. Exercise judgment within generally defined practices and policies.
• Proficiency in logic design, simulation
• Proficiency in Verilog and its simulation environment
• Good knowledge of IC design
• At least seven year experience working on digital IC development projects, excellent communication skills and the uncanny ability to both lead and contribute in a cooperative team environment.
• Essential Qualifications: Must have BS degree with 9~12+ years of applicable experience, MS degree with 7~10+ years of applicable experience in electrical engineering, microelectronics, comparable engineering science or solid state physics.
• Will have demonstrated successful completion of 10+ design projects as an individual contributor
• Familiar with JEDEC-DDR/HBM, DFI and AMBA protocols and have DDR project design experience
Title: Senior Principal Physical Design Engineer (数字后端设计项目方向)
• BS degree with 15+ years of applicable experience, MS degree with 12+ years of applicable experience in electrical engineering, microelectronics.
• Self-motivated, able to work independently or as a team player, excellent verbal and written communication skills in English. |
