查看: 10716|回复: 12
[资料] SIMetrix/SIMPLIS Elements is v8.10g
发表于 2018-7-3 13:19:22 | 显示全部楼层 |阅读模式
此版本有限制,但可以跑小電路及Example
..請大家考量後再下..謝謝. (限制說明如下,請看完再下.)
內容有..主程式及範例...
1. elements.exe
2. simplis_tutorial_examples.zip
3. Example Circuits Which Run in Elements
SIMetrix/SIMPLIS Elements is a free-to-download version of our software that offers full schematic capture and waveform viewing / analysis capability along with a host of documentation and training materials designed to help users get up-to-speed quickly with SIMetrix/SIMPLIS' simulation capabilities.
The latest version of SIMetrix/SIMPLIS Elements is v8.10g, released September 8, 2017.
Elements is a free version of the program with no license or copying restrictions. Virtually all features are enabled but a circuit size limit applies. The limits for the Elements versions are generous enough for them to be used for real work and we are happy for users to do so.
System Requirements
SIMetrix/SIMPLIS Elements requires Windows 10 (Home, Pro or Enterprise), Windows 8/8.1 (Standard, Professional or Enterprise) or Windows 7 (Home Premium or better).
SIMetrix/SIMPLIS Elements Limitations
Features
All features of the full production version are enabled except:
The command line is not present. This effectively inhibits any features that require the command line. There are, however, very few of these
User scripts
The Verilog-A compiler is not available. (Pro and Elite full licenses only)
Verilog-HDL mixed signal simulation is not available. (Pro and Elite full licenses only)
Custom menu and key definitions
The PSpice translator is limited to small schematics
SPICE3 raw file import
Safe Operating Area testing is not available
The menu/key editor is not available
Encrypted models are not supported
Some of the above features can be enabled for 30 days using the unlock feature. See menu Help | Unlock Features...
SIMPLIS Circuit Size Limits
The exact limits for the SIMPLIS simulator are:
A total of no more than 15 state variables.  A capacitor or an inductor each requires one state variable.  Each time-varying or small-signal AC source requires one state variable, with the exception of SINusoidal or COSinusoidal sources, which require two state variables per source.
A total of no more than 10 capacitors or inductors combined.
A total of no more than six switches, simple or transistor.
A total of no more than six logic gates.
A total of no more than 26 "states."  Each PWL element requires one state.  Each switch requires one state.  Each time-varying source requires one state.  Each logic gate requires one state.
A total of no more than 100 new topologies. 100 topologies will be enough for simple switching circuits that use simple models only. More complex circuits or circuits that have more complicated models may exceed this limit
SIMetrix Circuit Size Limits
There is a limit to the size of circuit that can be simulated. The exact limits for the SIMetrix simulator are:
140 analog nodes (internal and external - see note below)
360 digital nodes
720 digital ports
300 digital components
360 digital outputs
The node count includes all circuit nodes and some of these may be internal to device models. Opamp models, for example, will always have a number of internal nodes depending its complexity.
There are no limits on the complexity of the SIMetrix arbitrary source expressions or arbitrary logic block definitions.
There are no Limits on...
...the size of schematic that can be drawn or printed. You are welcome to use SIMetrix/SIMPLIS Elements as a free general purpose schematic drawing tool.
SIMetrix_SIMPLIS Elements V8.1.part1.rar (13.5 MB , 下载次数: 45 )
SIMetrix_SIMPLIS Elements V8.1.part2.rar
13.5 MB, 下载次数: 48 , 下载积分: 资产 -5 信元, 下载支出 5 信元
2
SIMetrix_SIMPLIS Elements V8.1.part3.rar
13.5 MB, 下载次数: 32 , 下载积分: 资产 -5 信元, 下载支出 5 信元
3
SIMetrix_SIMPLIS Elements V8.1.part4.rar
13.5 MB, 下载次数: 27 , 下载积分: 资产 -5 信元, 下载支出 5 信元
4
SIMetrix_SIMPLIS Elements V8.1.part5.rar
5
SIMetrix_SIMPLIS Elements V8.1.part6.rar
7
SIMetrix_SIMPLIS Elements V8.1.part7.rar
22.66 KB, 下载次数: 18 , 下载积分: 资产 -2 信元, 下载支出 2 信元
6
 楼主| 发表于 2018-7-3 17:40:15 | 显示全部楼层
回复 1# Jason_ke
在範例中..如果有缺元件時, 請將下面的model file放在範例中.並且將其路徑指向該元件即可.
Extra Model.rar (147.03 KB , 下载次数: 59 )
发表于 2018-7-20 18:06:36 | 显示全部楼层
tks for the great sharing!
发表于 2018-11-26 20:21:51 | 显示全部楼层
无法解包?
发表于 2018-11-26 20:25:48 | 显示全部楼层
刚才又试了下,其他帖子上的附件下载解包没问题,因此大家不要浪费信元了。
发表于 2019-7-3 14:05:23 | 显示全部楼层
s98006368 发表于 2018-11-26 20:25
刚才又试了下,其他帖子上的附件下载解包没问题,因此大家不要浪费信元了。 ...
我也无法解包 骗子
发表于 2019-7-12 18:26:42 | 显示全部楼层
确实好东西,仿真帮助很大.
发表于 2020-3-11 15:30:59 | 显示全部楼层
thank
发表于 2020-10-15 15:26:33 | 显示全部楼层
之前一直用这个软件,好久没用了!
发表于 2020-11-17 17:39:07 | 显示全部楼层
Thank you
GMT+8, 2025-9-17 11:35 , Processed in 0.020335 second(s), 6 queries , Gzip On, Redis On.
