查看: 4028|回复: 1
synopsys安装后无法打开
发表于 2018-6-19 23:41:57 | 显示全部楼层 |阅读模式
安装后显示Failed to open the TCP port number in the license.使用了很多方法,包括改端口,关防火墙,root启动端口,都不行,最后变成
3:36:13 (lmgrd) (@lmgrd-SLOG@) License file(s) used:  /home/caocao/synopsys/scl/admin/license/Synopsys.dat
23:36:13 (lmgrd) (@lmgrd-SLOG@) ===============================================
23:36:13 (lmgrd) Starting vendor daemons ...
23:36:13 (lmgrd) Started snpslmd (internet tcp_port 39384 pid 4267)
23:36:13 (snpslmd) FlexNet Licensing version v11.14.0.2 build 191018 x64_lsb
06/19/2018 23:36:13 (snpslmd) INFO: Pooling on VENDOR_STRING is Disabled (to enable, set SCL_POOL_VS=1)
06/19/2018 23:36:13 (snpslmd) Synopsys Corporate Licensing (SCL) Release: version SCL_2016.12
06/19/2018 23:36:17 (snpslmd) File descriptor limit (soft, hard) for snpslmd: 4096, 4096
23:36:17 (snpslmd) SLOG: Summary LOG statistics is enabled.
23:36:17 (snpslmd) SLOG: FNPLS-INTERNAL-CKPT1
23:36:17 (snpslmd) SLOG: VM Status: 1
06/19/2018 23:36:19 (snpslmd) Checking the integrity of the license file...
06/19/2018 23:36:19 (snpslmd) Valid SSS feature found.
06/19/2018 23:36:19 (snpslmd) The feature is needed to enable the other keys in your license file.
06/19/2018 23:36:19 (snpslmd) Licensed to student@eetop
06/19/2018 23:36:19 (snpslmd) Siteid: 26356, Server Hostid: 000c2992c249, Issued on: 1/8/2014
06/19/2018 23:36:19 (snpslmd) ------------------------------------------------------------------
23:36:20 (snpslmd) SLOG: Statistics Log Frequency is 240 minute(s).
23:36:20 (snpslmd) SLOG: TS update poll interval is 0. TS update is detected by midnight reread only.
23:36:20 (snpslmd) SLOG: Activation borrow reclaim percentage is 0.
23:36:20 (snpslmd) (@snpslmd-SLOG@) ===============================================
23:36:20 (snpslmd) (@snpslmd-SLOG@) === Vendor Daemon ===
23:36:20 (snpslmd) (@snpslmd-SLOG@) Vendor daemon: snpslmd
23:36:20 (snpslmd) (@snpslmd-SLOG@) Start-Date: Tue Jun 19 2018 23:36:20 CST
23:36:20 (snpslmd) (@snpslmd-SLOG@) PID: 4267
23:36:20 (snpslmd) (@snpslmd-SLOG@) VD Version: v11.14.0.2 build 191018 x64_lsb ( build 191018 (ipv6))
23:36:20 (snpslmd) (@snpslmd-SLOG@) === Startup/Restart Info ===
23:36:20 (snpslmd) (@snpslmd-SLOG@) Options file used: None
23:36:20 (snpslmd) (@snpslmd-SLOG@) Is vendor daemon a CVD: Yes
23:36:20 (snpslmd) (@snpslmd-SLOG@) Is TS accessed: No
23:36:20 (snpslmd) (@snpslmd-SLOG@) TS accessed for feature load: -NA-
23:36:20 (snpslmd) (@snpslmd-SLOG@) Number of VD restarts since LS startup: 0
23:36:20 (snpslmd) (@snpslmd-SLOG@) === Network Info ===
23:36:20 (snpslmd) (@snpslmd-SLOG@) Listening port: 39384
23:36:20 (snpslmd) (@snpslmd-SLOG@) Daemon select timeout (in seconds): 1
23:36:20 (snpslmd) (@snpslmd-SLOG@) === Host Info ===
23:36:20 (snpslmd) (@snpslmd-SLOG@) Host used in license file: caocao
23:36:20 (snpslmd) (@snpslmd-SLOG@) Running on Hypervisor: VMWare
请问有什么好办法吗
发表于 2020-4-2 19:39:55 | 显示全部楼层
楼主最后怎么解决的呀!同样的问题
GMT+8, 2025-9-17 03:23 , Processed in 0.012140 second(s), 3 queries , Gzip On, Redis On.
