查看: 3167|回复: 3
[讨论] ADC 仿真,输入信号不给full-scale信号,而是-0.5dB full-scale是什么理由?
发表于 2018-6-9 08:25:46 | 显示全部楼层 |阅读模式
请教一下,如题。多谢
很早之前看到过相关的解释,可现在找不到了。只是记得这样一个操作。
发表于 2018-6-9 09:26:51 | 显示全部楼层
因为实际应用时考虑peak to average
 楼主| 发表于 2019-5-2 05:08:47 | 显示全部楼层
For avoiding the situation of overdriving the quantizer, the input signal is set to be -0.5dBFS or -1dBFS. Whether it is 1 dB or 0.5 dB below full scale, it is done so as to prevent clipping of the signal if one were to run the ADC inputs at full-scale (0 dBFS)
As we know 0dBFS input amplitude is equal to full scale.
-0.5dBFS is about 94.4 % of full scale.
-1dBFS is about 89.1% of full scale.
发表于 2024-7-23 09:43:24 | 显示全部楼层
GMT+8, 2025-11-5 03:58 , Processed in 0.012498 second(s), 3 queries , Gzip On, Redis On.
