查看: 2863|回复: 2
[求助] 求助: CMOS & Beyond-Logic Switches for Terascale Integrated Circuits
发表于 2018-6-3 19:34:41 | 显示全部楼层 |阅读模式
書名:CMOS & Beyond-Logic Switches for Terascale Integrated Circuits作者:Tsu-Jae King Liu, Kelin Kuhn
介紹:
Get up to speed with the future of logic switch design with this indispensable overview of the most promising successors to modern CMOS transistors. Learn how to overcome existing design challenges using novel device concepts, presented using an in-depth, accessible, tutorial-style approach. Drawing on the expertise of leading researchers from both industry and academia, and including insightful contributions from the developers of many of these alternative logic devices, new concepts are introduced and discussed from a range of different viewpoints, covering all the necessary theoretical background and developmental context. Covering cutting-edge developments with the potential to overcome existing limitations on transistor performance, such as tunneling field-effect transistors (TFETs), alternative charge-based devices, spin-based devices, and more exotic approaches, this is essential reading for academic researchers, professional engineers, and graduate students working with semiconductor devices and technology.
 楼主| 发表于 2018-9-25 20:15:07 | 显示全部楼层
回复 1# Capricorn0115
再求~
发表于 2023-5-27 11:43:45 | 显示全部楼层
ding!!!!!
GMT+8, 2025-12-18 03:54 , Processed in 0.015304 second(s), 4 queries , Gzip On, Redis On.
