查看: 32585|回复: 154
Huijsing-Design of Low-Voltage,Low-Power Operational Amp Cell
发表于 2007-8-15 16:53:58 | 显示全部楼层 |阅读模式
Design of Low-Voltage, Low-Power Operational Amplifier Cells (The International Series in Engineering and Computer Science) (Hardcover)
by Ron Hogervorst, Johan H. Huijsing
Book Description
Design of Low-Voltage, Low-Power CMOS Operational Amplifier Cells describes the theory and design of the circuit elements that are required to realize a low-voltage, low-power operational amplifier. These elements include constant-gm rail-to-rail input stages, class-AB rail-to-rail output stages and frequency compensation methods. Several examples of each of these circuit elements are investigated. Furthermore, the book illustrates several silicon realizations, giving their measurement results. The text focuses on compact low-voltage low-power operational amplifiers with good performance. Six simple high-performance class-AB amplifiers are realized using a very compact topology making them particularly suitable for use as VLSI library cells. All of the designs can use a supply voltage as low as 3V. One of the amplifier designs dissipates only 50µW with a unity gain frequency of 1.5 MHz. A second set of amplifiers run on a supply voltage slightly above 1V. The amplifiers combine a low power consumption with a gain of 120 dB. In addition, the design of three fully differential operational amplifiers is addressed. Design of Low-Voltage, Low-Power CMOS Operational Amplifier Cells is intended for professional designers of analog circuits. It is also suitable for use as a text book for an advanced course in CMOS operational amplifier design.
Hardcover: 224 pages
Publisher: Springer; 1 edition (October 31, 1996)
Language: English
ISBN: 0792397819
abbr_8812eb0764ca82bf8b3579396918c42f.rar
4.77 MB, 下载次数: 1173 , 下载积分: 资产 -3 信元, 下载支出 3 信元
abbr_f69d945fcbb034dd393ef7e5d3468160.rar
4.77 MB, 下载次数: 1090 , 下载积分: 资产 -3 信元, 下载支出 3 信元
abbr_f5f47218cdbbd018ecdec26c9f9404eb.rar
161.61 KB, 下载次数: 580 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2007-8-15 17:22:48 | 显示全部楼层
忘记说了文件是DJVU格式的。。。
要下阅读器。。。。
给大家带来不便望见谅。。
 楼主| 发表于 2007-8-15 17:28:31 | 显示全部楼层
附上阅读器。。。。。。
WinDjView0.43.rar
509.09 KB, 下载次数: 252 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2007-8-15 19:21:12 | 显示全部楼层
书是好书,可是质量较差
发表于 2007-8-16 00:10:33 | 显示全部楼层
士大夫就卡后果法
发表于 2007-8-16 00:11:51 | 显示全部楼层
sdjfcldsfjafsldgreghiregraifrgfkrhg
发表于 2007-8-16 00:13:03 | 显示全部楼层
lkdsfjlarjgerhftrwtlesjfewklfwrjgt
发表于 2007-8-16 00:21:33 | 显示全部楼层
可以可以可以
发表于 2007-8-16 00:23:19 | 显示全部楼层
elswahfroi3qtfh4wlwthfwqugftoi3qrhftoiu3
 楼主| 发表于 2007-8-16 08:22:08 | 显示全部楼层
谢谢支持。。。
GMT+8, 2025-12-30 14:10 , Processed in 0.150751 second(s), 6 queries , Gzip On, Redis On.
