查看: 9119|回复: 10
spyglass运行报错,求大神。。。
发表于 2018-3-31 20:31:57 | 显示全部楼层 |阅读模式
spyglass: INTERNAL-ERROR, the VALUE OF `$SPYGLASS_HOME' (an internal variable) was not intuited correctly.
spyglass:                 The value guessed was: `SPYGLASS_HOME=/home/h/software/synopsys/SpyGlass-L2016.06/SPYGLASS_HOME'
spyglass: INTERNAL-ERROR, the Perl 5 installation within `$SPYGLASS_HOME' could not be validated.
spyglass:                 A perl installation was expected at: `/home/h/software/synopsys/SpyGlass-L2016.06/SPYGLASS_HOME/lib/multi-perl'
spyglass:                 either `$SPYGLASS_HOME' was guessed incorrectly or the installation is corrupted.
spyglass: NOTE, the caller's environment variable `$SPYGLASS_HOME' was ignored in this process.
以上是报错内容,感觉像是环境变量设置的问题,但是我的环境变量设置好了,如下:
export SPYGLASS_HOME=/home/h/software/synopsys/SpyGlass-L2016.06/SPYGLASS_HOME/
export PATH=$SPYGLASS_HOME/binPATH
求帮忙!
发表于 2018-3-31 23:43:25 | 显示全部楼层
回复 1# haoyz
   应该是环境变量的问题
发表于 2018-4-1 07:34:40 | 显示全部楼层
这工具是干嘛用的
 楼主| 发表于 2018-4-1 10:07:15 | 显示全部楼层
回复 3# maomao198477
    power评估,lint检查,dft检查,功能很丰富
 楼主| 发表于 2018-4-1 10:08:10 | 显示全部楼层
回复 2# joycechou1110
    谢谢回复,请问能帮忙具体分析下环境变量哪里的问题呢?
发表于 2018-6-23 06:19:27 | 显示全部楼层
发表于 2018-6-23 13:59:24 | 显示全部楼层
回复 1# haoyz
   http://bbs.eetop.cn/viewthread.php?tid=604891&pid=9704081&page=11&extra=#pid9704081
发表于 2020-3-25 12:52:01 | 显示全部楼层
solution works 多谢
发表于 2020-5-21 01:29:48 | 显示全部楼层
thanks
发表于 2021-1-10 18:13:39 | 显示全部楼层
ERROR(perl): Unknown platform: Linux-4.18.0-240.el8.x86_64
SpyGlass Rule Checking Aborted.
怎么解决?
GMT+8, 2025-12-11 07:29 , Processed in 0.019264 second(s), 5 queries , Gzip On, Redis On.
