查看: 4969|回复: 4
ncverilog gcc問題(incisive131 version)
发表于 2018-1-15 09:01:37 | 显示全部楼层 |阅读模式
各位高手有沒有知道以下錯誤要如何解決?
/home/user/cadence/INCISIV131/tools.lnx86/cdsgcc/gcc/4.4/install/bin/gcc: 2: /home/user/cadence/INCISIV131/tools.lnx86/cdsgcc/gcc/4.4/install/bin/gcc: Syntax error: Unterminated quoted string
ncelab: *W,DPIEXP: DPI export function in  _sv_export.so not available.
/home/user/cadence/INCISIV131/tools.lnx86/cdsgcc/gcc/4.4/install/bin/gcc: 1: /home/user/cadence/INCISIV131/tools.lnx86/cdsgcc/gcc/4.4/install/bin/gcc: ELF: not found
/home/user/cadence/INCISIV131/tools.lnx86/cdsgcc/gcc/4.4/install/bin/gcc: 1: /home/user/cadence/INCISIV131/tools.lnx86/cdsgcc/gcc/4.4/install/bin/gcc: ELF: not foundncelab: *W,DPIEXP: DPI export function in  _sv_export.so not available.
/home/user/cadence/INCISIV131/tools/perl/bin/cdsPerl: 1: /home/user/cadence/INCISIV131/tools/perl/bin/cdsPerl: Syntax error: ")" unexpected
irun: *E,CCERR: Error during cc compilation (status 2), exiting.
我看了安裝的incisive131的目錄下有gcc 4.4版本,但無法看出錯誤發生在哪裡???還是少安裝了什麼???
 楼主| 发表于 2018-1-15 11:13:50 | 显示全部楼层
回复 1# tezhi
我把incisiv安裝目錄下的gcc 4.4 delete, 剩下gcc 4.1會變成以下錯誤(少了一個),但還是錯?
发表于 2018-1-15 19:11:13 | 显示全部楼层
compile your project step by step , then you will find the problem.
 楼主| 发表于 2018-1-16 08:45:20 | 显示全部楼层
回复 3# phoenixson
thanks your answer,I try step by step, 1. ncvlog, 2. ncelab,  3. ncsim
 楼主| 发表于 2018-1-16 15:56:54 | 显示全部楼层
回复 3# phoenixson
以下是sv file and c file
///////helo.c//////////////////
#include <stdio.h>
#include "svdpi.h"
void reportc()
printf("Hello World from C! ");
printf("tezhi test! ");
///////helo.sv//////////////////
program main();
import "DPI-C" reportc=task reportc();
export "DPI-C" task DPI_waitNs;
initial
begin
  reportc();
end
task DPI_waitNs (input int unsigned ns);
    #(ns);
endtask
endprogram
step1. 我在ncvlog下run了helo.sv,命令如下:
ncvlog -sv hello.sv
編譯此sv file沒有問題。
step2. 我再elaborate the design,命令如下:
ncelab main
執行此步驟卻發生了錯誤
這是export "DPI-C" task DPI_waitNs這行發生了問題,沒辦法export DPI-C,
svdpi.h檔案有在資料夾之中,是缺少了DPI相關檔案嗎?
要如何才能解決這個錯誤???
GMT+8, 2025-12-17 06:41 , Processed in 0.016001 second(s), 4 queries , Gzip On, Redis On.
