查看: 1200|回复: 0
[招聘] 【英伟达NVIDIA】上海研发中心招聘: Senior ASIC Design Verification Engineer
发表于 2017-12-24 23:13:25 | 显示全部楼层 |阅读模式
职位诱惑: 技术领先,成长空间大,年终奖金,五险一金
工作地址:上海浦东新区秋月路26号
简历投递邮箱:heatherl@nvidia.com,简历请以附件形式发送
岗位职责:
You will participate in the research of verification methodology toimprove automation and productivity to produce Nvidia’s new high-quality stateof the art products.
Read IAS and design specs to understand the design requirement andbuild corresponding testplan. Review the testplan with arch/design engineers.
You responses to build block/IP testbench based on UVM methodology.
The responsibilities includes building test run and regression flow.Triage failures in regression and help designer root cause the bug.
Work includes Build various metrics (passing rate, functional coverage,etc) and monitor its health.
Take SOC verification on fullchip test environment for IPs
Analyse functional/code coverage result and identify the coverageholes. Work with design engineer to improve the coverage score.
1.
Deploy the advanced verification methodology andinfrastructure of the SOC/IP
要求:
电子/通信/计算机相关专业本科及以上学历
硕士3年以上行业经验,本科5年以上行业经验
熟悉UVM/VMM/OVM等验证方法,工具及流程
熟悉验证流程,包括testplan,test, coverage model, testbench, BFM modeling.
对Verilog andHVL语言有深入理解
加分项:
掌握Perl ,C或C++ 语言
有架构/设计相关经验
掌握以下任一脚本语言 Shell,Ruby, Python
良好的交流能力,分析能力和团队合作能力
【英伟达NVIDIA简介】
NVIDIA 公司是全球视觉计算技术的行业领袖及GPU (图形处理器) 的发明者,总部位于美国加利福尼亚州的圣克拉拉市,在20多个国家和地区拥有约5700名员工。公司在可编程图形处理器方面拥有先进的专业技术,在并行处理方面实现了诸多突破。
GMT+8, 2025-11-5 04:47 , Processed in 0.013177 second(s), 4 queries , Gzip On, Redis On.
