查看: 6453|回复: 12
[求助] 安装IC617+MMSIM151后仿真时出现报错
发表于 2017-12-10 21:31:05 | 显示全部楼层 |阅读模式
在安装完IC617+MMSIM151后对上述软件安装成功与否,做了一个简单的电路进行验证,仿真时出现如下报错
Entering remote command mode using MPSC service (spectre, ipi, v0.0, spectre0_5962_2, ).
Warning from spectre.
    WARNING (SPECTRE-16707): Only tran supports psfxl format, result of other analyses will be in psfbin format.
网表如下:
执行./runSimulation出现如下错误
这个软件安装已经花费好久时间了,希望知道的人帮帮忙
发表于 2017-12-11 11:11:41 | 显示全部楼层
这是爱的奉献
发表于 2018-6-14 16:14:52 | 显示全部楼层
同样的问题有解决了吗,在ic5141,mmsim0下正常
发表于 2018-6-14 16:15:34 | 显示全部楼层
发表于 2018-6-14 16:17:22 | 显示全部楼层
发表于 2018-6-14 16:18:16 | 显示全部楼层
发表于 2018-6-14 16:30:48 | 显示全部楼层
spectre 软件路径的变量设置的有问题吧
发表于 2018-6-14 16:35:20 | 显示全部楼层
export MMSIM_ROOT=/opt/cadence/installs/MMSIM141
export PATH=$MMSIM_ROOT/tools/binMMSIM_ROOT/tools/spectre/binPATH
发表于 2018-6-15 23:09:08 | 显示全部楼层
ic616和mmsim13、mmsim10结合多会有WARNING,但是用ic5141和mmsim10跑没有警告,具体如下
Simulating `input.scs' on homehost at 8:53:38 PM, Fri Jun 15, 2018 (process id: 5105).
Current working directory: /home/jq/simulation/inv/spectre/schematic/netlist
Command line:
    /opt/eda/mmsim131/tools/spectre/bin/32bit/spectre input.scs  \
        +escchars +log ../psf/spectre.out +inter=mpsc  \
        +mpssession=spectre1_3911_1 -format psfxl -raw ../psf  \
        +lqtimeout 900 -maxw 5 -maxn 5
spectre pid = 5105
Loading /opt/eda/mmsim131/tools.lnx86/cmi/lib/5.0/libinfineon_sh.so ...
Loading /opt/eda/mmsim131/tools.lnx86/cmi/lib/5.0/libphilips_o_sh.so ...
Loading /opt/eda/mmsim131/tools.lnx86/cmi/lib/5.0/libphilips_sh.so ...
Loading /opt/eda/mmsim131/tools.lnx86/cmi/lib/5.0/libsparam_sh.so ...
Loading /opt/eda/mmsim131/tools.lnx86/cmi/lib/5.0/libstmodels_sh.so ...
Reading file:  /home/jq/simulation/inv/spectre/schematic/netlist/input.scs
Reading file:  /opt/eda/mmsim131/tools.lnx86/spectre/etc/configs/spectre.cfg
Reading file:  /home/jq/model/MIXDTSSA01V12/mixdtssa01v12.scs
Reading file:  /home/jq/model/MIXDTSSA01V12/res_va.va
Reading link:  /opt/eda/mmsim131/tools.lnx86/spectre/etc/ahdl/discipline.h
Reading file:  /opt/eda/mmsim131/tools.lnx86/spectre/etc/ahdl/disciplines.vams
Reading link:  /opt/eda/mmsim131/tools.lnx86/spectre/etc/ahdl/constants.h
Reading file:  /opt/eda/mmsim131/tools.lnx86/spectre/etc/ahdl/constants.vams
Entering remote command mode using MPSC service (spectre, ipi, v0.0, spectre1_3911_1, ).
发表于 2018-6-16 21:38:05 | 显示全部楼层
不是,7楼、8楼所说的问题
GMT+8, 2025-12-19 09:09 , Processed in 0.205318 second(s), 4 queries , Gzip On, Redis On.
