查看: 2006|回复: 2
EDI141 installation problem
发表于 2017-11-10 02:44:10 | 显示全部楼层 |阅读模式
I installed cadence encounter EDI141 on centos 64 bit add export EDI_bin directory into .bashrc and source it
when I run command encounter &
I get the following error "can not find shared libraries"
I searched for library name and made link to it into / user / lib64
when I run encounter &
I got the same error but for different library name
发表于 2017-11-10 11:21:36 | 显示全部楼层
1)install local media repository
2) run 'yum provides xxx.so'
3) install the package that is found above.
have fun.
 楼主| 发表于 2017-11-22 11:36:47 | 显示全部楼层
thanks
GMT+8, 2025-12-16 18:30 , Processed in 0.012943 second(s), 4 queries , Gzip On, Redis On.
