AMD超威半导体上海研发中心招聘 SMTS Front-End Integration Engineer, 请将简历发送到 Cherry.Zhang@amd.comRESPONSIBILITIES:• The successful candidate will assume technical leadership of a complex design generally including custom digital logic, an embedded u-controller and analog functionality. The following is a list of key responsibilities that the candidate will assume:• Micro-architecture of digital blocks, hardware firmware partitioning.• Leading a small team of engineers• Digital design and RTL coding for.• Writing firmware for embedded u-controllers in C• Occasional creation of utility software in using C++, perl, php• Co-ordinating design verification and implementation activities.REQUIREMENTS:• Minimum 5-6 years of experience with Verilog a MUST• Excellent knowledge of verilog, C, C++ and a scripting language; experience with Perl and TCL is a plus• Strong understanding of digital and analog electronics.• Experience with low level, physical phenomena oriented logic design is an asset (dealing with IO, clocking, voltage control, etc.)• Power/thermal management experience is an asset.• Security/cryptography experience is an asset• Good understanding of computer organization/architecture.• Laboratory experience, including the use of equipment: oscilloscopes, logic analyzers, etc.• Strong analytical/problem solving skills and pronounced attention to details.• Must be a self starter, and able to independently drive tasks to completion.• Strong interpersonal and communication skillsEDUCATION:• Bachelor, Master's or PhD degree in Electrical or Computer engineering. |
