查看: 13362|回复: 31
[原创] Embedded Systems with ARM Cortex-M.Microcontrollers in Assembly.Language and C:
发表于 2017-10-8 20:22:34 | 显示全部楼层 |阅读模式
I am looking for this books..
any one could share I will appreciate it alot.
Embedded Systems with ARM Cortex-M Microcontrollers in Assembly Language and C: Third Edition
by Yifeng Zhu
Significant changes in the third edition include updated serial communication description (UART, SPI, and I2C), new serial communication examples, incorporation of GNU gcc compiler, low power modes, modification of example programs from STM32L1 (Cortex-M3) to STM32L4 (Cortex-M4).
The book introduces basic programming of ARM Cortex-M cores in assembly and C at the register level, and the fundamentals of embedded system design. It presents basic concepts such as data representations (integer, fixed-point, floating-point), assembly instructions, stack, and implementing basic controls and functions of C language at the assembly level. It covers advanced topics such as interrupts, mixing C and assembly, direct memory access (DMA), system timers (SysTick), multi-tasking, SIMD instructions for digital signal processing (DSP), and instruction encoding/decoding. The book also gives detailed examples of interfacing peripherals, such as general purpose I/O (GPIO), LCD driver, keypad interaction, stepper motor control, PWM output, timer input capture, DAC, ADC, real-time clock (RTC), and serial communication (USART, I2C, SPI, and USB).
 楼主| 发表于 2018-6-28 11:50:17 | 显示全部楼层
still no update
发表于 2018-9-4 22:02:30 | 显示全部楼层
thanks for sharing
发表于 2019-3-17 01:37:06 | 显示全部楼层
best  best  good
发表于 2019-3-17 01:37:17 | 显示全部楼层
best  best  good
发表于 2019-4-11 08:16:38 | 显示全部楼层
good job.
发表于 2020-8-15 09:38:34 | 显示全部楼层
where is the link
发表于 2020-11-27 14:30:51 | 显示全部楼层
谢谢分享
发表于 2021-1-12 15:55:53 | 显示全部楼层
where is the link
发表于 2021-1-23 11:36:16 | 显示全部楼层
THANKS!!
GMT+8, 2025-12-30 04:57 , Processed in 0.023949 second(s), 5 queries , Gzip On, Redis On.
