查看: 4587|回复: 6
[求助] 找書: Battery Power Management for Portable Devices
发表于 2017-8-31 21:02:25 | 显示全部楼层 |阅读模式
Battery Power Management for Portable DevicesAuthor:
  • Yevgen Barsukov Yevgen Barsukov is an IP development manager for battery management systems business units at Texas Instruments. He holds an M.S. in organic chemistry from Kiev National University in the Ukraine and a Ph.D. in physical chemistry from Kiel Christian Albrecht University in Germany.
  • Jinrong Qian Jinrong Qian is a sector manager and distinguished member of technical staff for battery management systems at Texas Instruments. He holds M.S. degrees in power electronics from both the University of Central Florida and Zhejiang University in China and earned his Ph.D. in electrical engineering from the Virginia Polytechnic Institute and State University.
Description:
The introduction of Li-ion batteries in 1991 created a tremendous change in the handheld devices landscape. Since then, the energy stored and put to use in palm-sized electronic devices has quadrupled. Devices are continuously getting more power hungry, outpacing battery development. Written by leading engineers in the field, This cutting-edge resource helps you overcome this challenge, offering you an insightful overview and in-depth guide to the many varied areas of battery power management for portable devices. You find the latest details on optimizing charging circuits, developing battery gauges that provide the longest possible run-time while ensuring data protection, and utilizing safety circuits that provide multiple independent levels of protection for highly energetic batteries. This unique book features detailed design examples of whole systems, providing you with the real-world perspective needed to put this knowledge into practice. You get the state-of-the-art know-how you need to perfect your device designs, helping you make them strong competitors in the fast-growing portable device marketplace
 楼主| 发表于 2017-10-5 20:40:22 | 显示全部楼层
回复 1# Capricorn0115
发表于 2017-10-17 10:29:15 | 显示全部楼层
支持帮顶
发表于 2017-12-21 09:22:04 | 显示全部楼层
帮顶!!!!!!!!!!!!!!!!!!!
发表于 2017-12-24 14:16:28 | 显示全部楼层
发表于 2020-1-2 09:33:27 | 显示全部楼层
帮顶帮顶!
发表于 2020-5-29 13:30:13 | 显示全部楼层
thnak
GMT+8, 2025-12-9 17:42 , Processed in 0.017254 second(s), 5 queries , Gzip On, Redis On.
