楼主: lkkl54
silvaco中如何用atlas实现三维仿真
发表于 2018-5-9 10:59:43 | 显示全部楼层
回复 10# hanbinggushi
   在用的
发表于 2018-6-9 03:12:34 | 显示全部楼层
请问楼主内存耗尽怎么解决
发表于 2018-6-9 03:14:07 | 显示全部楼层
回复 8# czym520 请问楼主内存耗尽怎么解决
发表于 2018-6-9 03:27:34 | 显示全部楼层
回复 11# czym520
楼主内存耗尽怎么办,我的程序
#####開啟 ATLAS TCAD 模擬#####
go atlas
#####設定結構空間之 mesh(l mesh 位置,s mesh 密度)#####
mesh three.d
x.m l=0.0         s=0.0002
x.m l=0.004      s=0.00005
x.m l=0.005      s=0.00005
x.m l=0.01         s=0.0002
x.m l=0.013      s=0.00005
x.m l=0.014      s=0.00005
x.m l=0.018      s=0.0002
y.m l=-0.006     s=0.0005
y.m l=-0.004     s=0.0005
y.m l=-0.003     s=0.0001
y.m l=-0.002     s=0.0001
y.m l=0.0         s=0.00025
y.m l=0.002       s=0.0001
y.m l=0.003       s=0.0001
y.m l=0.004       s=0.0005
y.m l=0.006       s=0.0005
z.m l=-0.006     s=0.0005
z.m l=-0.004     s=0.0005
z.m l=-0.003     s=0.0001
z.m l=-0.002     s=0.0001
z.m l=0.0          s=0.00025
z.m l=0.002       s=0.0001
z.m l=0.003       s=0.0001
z.m l=0.004       s=0.0005
z.m l=0.006       s=0.0005
#####設定區域材料#####
region num=3 material=air
###Gate dielectric
region       num=2     sio2   x.min=0.005 x.max=0.013 y.min=-0.003y.max=0.003
z.min=-0.003  z.max=0.003
###S/D extension and channel region
#nanowire w/ constriction
region       num=1     silicon       x.min=0.0          x.max=0.004         y.min=-0.002
y.max=0.002 z.min=-0.002 z.max=0.002
region       num=1     silicon       x.min=0.004     x.max=0.005         y.min=-0.0015
y.max=0.0015 z.min=-0.0015 z.max=0.0015
region       num=1     silicon       x.min=0.005     x.max=0.017         y.min=-0.002
region       num=1     silicon       x.min=0.017     x.max=0.018         y.min=-0.0015
region       num=1     silicon       x.min=0.018     x.max=0.022         y.min=-0.002
#nanowire w/o constriction
region num=1 silicon x.min=0.0 x.max=0.018y.min=-0.002 y.max=0.002 z.min=-0.002 z.max=0.002
###Electrode region
#S/D electrode
electrode num=2 name=source x.max=0.0y.min=-0.002 y.max=0.002 z.min=-0.002 z.max=0.002
electrode num=3 name=drain x.min=0.018y.min=-0.002 y.max=0.002 z.min=-0.002 z.max=0.002
#Gate electrode
electrode num=1 name=gate x.min=0.005x.max=0.013 y.min=-0.006 y.max=-0.003 z.min=-0.006 z.max=0.006
electrode num=1 name=gate x.min=0.005x.max=0.013 y.min=0.003 y.max=0.006 z.min=-0.006 z.max=0.006
electrode num=1 name=gate x.min=0.005x.max=0.013 y.min=-0.003 y.max=0.003 z.min=0.003 z.max=0.006
electrode num=1 name=gate x.min=0.005x.max=0.013 y.min=-0.003 y.max=0.003 z.min=-0.006 z.max=-0.003
#####Contact boundary condition#####
contact name=source reflect
contact name=drain reflect
contact name=gate aluminum
#####Silicon doping#####
doping region=1 n.type uniform conc=1.0E20        x.min=0.0 x.max=0.018
#####Schrodinger Poisson mesh( Schrodingerequation mesh)#####
spx.m l=0.0       s=0.0002
spx.m l=0.004  s=0.00005
spx.m l=0.005  s=0.00005
spx.m l=0.01     s=0.0002
spx.m l=0.013  s=0.00005
spx.m l=0.014  s=0.00005
spx.m l=0.018  s=0.0002
spy.m l=-0.006 s=0.0005
spy.m l=-0.004 s=0.0005
spy.m l=-0.003 s=0.0001
spy.m l=-0.002 s=0.0001
spy.m l=0.0       s=0.00025
spy.m l=0.002  s=0.0001
spy.m l=0.003  s=0.0001
spy.m l=0.004  s=0.0005
spy.m l=0.006  s=0.0005
spz.m l=-0.006 s=0.0005
spz.m l=-0.004 s=0.0005
spz.m l=-0.003 s=0.0001
spz.m l=-0.002 s=0.0001
spz.m l=0.0       s=0.00025
spz.m l=0.002  s=0.0001
spz.m l=0.003  s=0.0001
spz.m l=0.004  s=0.0005
spz.m l=0.006  s=0.0005
#####Quantum transport model(NEGFapproach)#####
output band.par con.band val.band eigens=5 impact
MODELS SCHROSP.FAST NEGF_MS
SP.GEOM=2Dyz method CARRIERS=0
probe Transmissionfilename="VBT_TranvsE"
#####設定模擬偏壓條件求解與輸出條件設定#####
solve init
solve v2=0.0 v3=1.0 v1=0.2
log outf=JL8nm_ALUgate_negf_Vd1V_IdVg.log
solve v2=0.0 v3=1.0 v1=0.2 vstep=-0.02vfinal=-1.2 name=gate
log off
saveoutf=JL8nm_ALUgate_negf_Vd1000mV_Vg-1200mV.str negf.log
quit
 楼主| 发表于 2018-6-15 14:13:26 | 显示全部楼层
回复 14# s304425
   网格太密了,你只能先想办法将网格定义的稀疏一点,试试0.01这个量级的。
GMT+8, 2025-12-29 00:28 , Processed in 0.016770 second(s), 4 queries , Gzip On, Redis On.
