查看: 15044|回复: 28
vcs安装后不能正确运行
发表于 2017-7-24 11:18:33 | 显示全部楼层 |阅读模式
各位大神好:
小弟在Ubuntu 16.04上安装VCS2016.06
在借鉴之前VCS 2014等破解方法,并实践后,出现以下头疼的情况:
1) 编写简单的temp.v文件为测试例,对vcs安装情况进行检验,第一次运行时报出以下错误
  1. [lipn@lipn-P50 ~/workspace/verilog]cat temp.v
  2. `define A_C 1
  3. `define B_B 2
  4. module temp;
  5. endmodule
  6. [lipn@lipn-P50 ~/workspace/verilog]vcs temp.v
  7.                          Chronologic VCS (TM)
  8.          Version L-2016.06_Full64 -- Mon Jul 24 10:31:43 2017
  9.                Copyright (c) 1991-2016 by Synopsys Inc.
  10.                          ALL RIGHTS RESERVED
  11. This program is proprietary and confidential information of Synopsys Inc.
  12. and may be used and disclosed only as authorized in a license agreement
  13. controlling such use and disclosure.
  14. vcs1: ../../PhdlCore/EncryptionUtils.c:322: Prd2: Assertion `messageLength != 0' failed.
  15. Got SIGABRT
  16. Command line: /home/lipn/Software/Synopsys/vcs/software/linux64/bin/vcs1 -Mcc=gcc -Mcplusplus=g++ -Masflags= "-Mcfl= -pipe -fPIC -O -I/home/lipn/Software/Synopsys/vcs/software/include " "-Mxcflags= -pipe -fPIC -I/home/lipn/Software/Synopsys/vcs/software/include" "-Mldflags= -rdynamic " -Mout=simv -Mamsrun= -Mvcsaceobjs= "-Mobjects= /home/lipn/Software/Synopsys/vcs/software/linux64/lib/libvirsim.so /home/lipn/Software/Synopsys/vcs/software/linux64/lib/liberrorinf.so /home/lipn/Software/Synopsys/vcs/software/linux64/lib/libsnpsmalloc.so " -Mexternalobj= -Msaverestoreobj=/home/lipn/Software/Synopsys/vcs/software/linux64/lib/vcs_save_restore_new.o -Mcrt0= -Mcrtn= -Mcsrc= "-Msyslibs=-ldl " -full64 -picarchive -gen_obj temp.v
  17. --- Stack trace follows:
  18. [New LWP 2888]
  19. [Thread debugging using libthread_db enabled]
  20. Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
  21. 0x00007ff329db830d in nanosleep () from /lib/x86_64-linux-gnu/libc.so.6
  22.
    复制代码
2) 在第二次编译时,就卡在disclosure这里,不再提示任何消息
  1. [lipn@lipn-P50 ~/workspace/verilog]vcs temp.v
  2. Chronologic VCS (TM)
  3. Version L-2016.06_Full64 -- Mon Jul 24 10:45:05 2017
  4. Copyright (c) 1991-2016 by Synopsys Inc.
  5. ALL RIGHTS RESERVED
  6. This program is proprietary and confidential information of Synopsys Inc.
  7. and may be used and disclosed only as authorized in a license agreement
  8. controlling such use and disclosure.
  9.
    复制代码
3) 运行lmgrd后能正确执行一次dve,第二次再运行时,就完全不能弹出图形界面了
遇到这种情况,各位大神有什么建议,谢谢!
发表于 2017-7-24 14:36:47 | 显示全部楼层
license问题,请使用附件制作license
scl_keygen.rar
4.44 MB, 下载次数: 1728 , 下载积分: 资产 -3 信元, 下载支出 3 信元
 楼主| 发表于 2017-7-24 15:10:41 | 显示全部楼层
回复 2# joycechou1110
license有什么问题,您没说明白
发表于 2017-7-24 15:13:59 | 显示全部楼层
回复 3# lipn
嗯嗯
 楼主| 发表于 2017-7-24 15:18:27 | 显示全部楼层
[lipn@lipn-P50 ~/Software/Synopsys/scl/amd64/bin]sssverify /synopsys/license/synopsys.dat
Integrity check report for license file "/var/tmp/cNCTQU".
Report generated on 24-Jul-2017 (SCL_11.7)
Checking the integrity of the license file....
Valid SSS feature found.
Licensed to mammoth//ZWT 2006
Siteid: <No Site Id>, Server Hostid: 507B9DB1A343, Issued on: N/A
License file integrity check PASSED!
You may now USE this license file to start your license server.
Please don't edit or manipulate the contents of this license file.
发表于 2017-7-30 17:37:36 | 显示全部楼层
2016版本以后,不是SCL验证能通过就能用的
发表于 2017-8-3 16:53:21 | 显示全部楼层
回复 5# lipn
   楼主,你搞定了没,我的2016也是这个问题
 楼主| 发表于 2017-8-4 14:42:54 | 显示全部楼层
 楼主| 发表于 2017-8-4 14:43:39 | 显示全部楼层
回复 4# joycechou1110
   特别感谢这位大神~
发表于 2017-8-4 22:40:34 | 显示全部楼层
太牛了 大神
GMT+8, 2025-12-14 18:22 , Processed in 0.019746 second(s), 4 queries , Gzip On, Redis On.
