查看: 4241|回复: 3
[求助] how to break a timing loop
发表于 2017-7-1 08:26:51 | 显示全部楼层 |阅读模式
I got the information saying timng loop detected: nformation: Timing loop detected. (OPT-150)
I_ORCA_TOP/I_RISC_CORE/I_REG_FILE/REG_FILE_A_RAM_1/OEB1 I_ORCA_TOP/I_RISC_CORE/I_REG_FILE/REG_FILE_A_RAM_1/IO1[16]
and a lot of warning saying
Warning: Disabling timing arc between pins 'OEB1' and 'IO1[16]' on cell 'I_ORCA_TOP/I_RISC_CORE/I_REG_FILE/REG_FILE_A_RAM_1'
         to break a timing loop. (OPT-314)
They looked that DC is suggesting that I could disabling timing arc between OEB1 and IO1[16] to break a timing loop
Please help, how do I do that, disabling timing arc between OEB1 and IO1[16]
发表于 2017-7-3 10:44:08 | 显示全部楼层
insert DFF in the timing loop
 楼主| 发表于 2017-7-3 22:16:07 | 显示全部楼层
回复 2# swary
Thank you for replyingCould you explain more in details how?
Change the source code?
发表于 2017-7-4 08:19:59 | 显示全部楼层
I have no experience about it. Only has a little information about. I work on front-end.
GMT+8, 2025-12-28 19:49 , Processed in 0.013588 second(s), 3 queries , Gzip On, Redis On.
