查看: 1867|回复: 2
[求助] help to run ic614
发表于 2017-6-11 14:41:09 | 显示全部楼层 |阅读模式
I installed ic06.14 to /home/tools/cadence/ic06.14, without any issue
Please help
when I tried to run virtuoso, I got these:
ERROR: Could not find Cadence installation root for
/home/tools/cadence/ic06.14/tools/bin/cdsGetOABinPath
Make sure that cdsGetOABinPath is part of the Cadence installation.
virtuoso:   ERROR: No proper OA2.2 installation found. Fix the errors reported by cdsGetOABinPath.
virtuoso:    INFO: Note that OpenAccess (OA) requires running the Configure phase.
virtuoso:          See the "OpenAccess Installation and Configuration Guide" before
virtuoso:          you complete the configuration step. This manual is included with
virtuoso:          the Cadence product documentation.
发表于 2017-6-11 23:19:24 | 显示全部楼层
回复 1# xiaoyisimonguo
环境变量设置的有问题,可以搜一下论坛,写的很详细
发表于 2017-6-12 09:53:49 | 显示全部楼层
估计没有设置OA_HOME
GMT+8, 2025-12-26 22:10 , Processed in 0.013472 second(s), 4 queries , Gzip On, Redis On.
