查看: 3976|回复: 1
[求助] ADS2016关于使用FEM的破解失效问题
发表于 2017-5-31 00:53:46 | 显示全部楼层 |阅读模式
大家好,我用论坛上的破解办法安装了ADS 2016,刚开始都是可以用了,没问题。
在跑完一次momentum FEM仿真之后,接下来再跑另一个FEM仿真。
然后在EM setup窗口,会提示说port设置等与上一次设置相比改变了。
关掉这个提示窗口(不知道和它有没有关系),
再跑FEM仿真,就开始报错了。
Setting EMPROHOME to D:\Keysight\ADS\fem\2016.01/Win32_64/bin
FemEngine
Version:FEM FemEngine_64 12.00 (*) built: Jan 14 2016
Target dataset file: testDEMO1_CUT3_FEM
Problems with environment variables! Check if EMPROHOME is set correctly.
Traceback (most recent call last):
  File "D:\Keysight\ADS\Momentum\12.00\fem_scripts\sim.py", line 1209, in <module>
    main()
  File "D:\Keysight\ADS\Momentum\12.00\fem_scripts\sim.py", line 1203, in main
    simObject.import_settings_and_simulate(stop_after_project_creation)
  File "D:\Keysight\ADS\Momentum\12.00\fem_scripts\sim.py", line 876, in import_settings_and_simulate
    self.setEnvironment()
  File "D:\Keysight\ADS\Momentum\12.00\fem_scripts\sim.py", line 308, in setEnvironment
    import empro
  File "D:\Keysight\ADS\fem\2016.01/Win32_64/bin\empro\__init__.py", line 5, in <module>
    import libpyempro
TypeError: PyModule_AddObject() needs non-NULL value
然后就error,跑不下去了。
这时候在EM setup里返回 MOMENTUM Microwave来跑仿真,结果就开始报license错误。
License check returned: Momentum Object
The desired vendor daemon is down
Possible Causes:
1. lmgrd process is running, but not the agileesofd vendor daemon. The software was able to contact the license server (lmgrd), but the vendor daemon (agileesofd) did not respond.
2. agileesofd vendor daemon has crashed or has been terminated.
3. lmgrd process was shut down manually or via LMTools with -x lmdown option
4. On Windows platform, this could be caused by waking up from Sleep or Hibernation mode.
5. The logfile was unable to be removed.
Troubleshooting Tips:
1. Check the license server's debug log file and try lmreread.
2. Reboot your system to restart the license service.
3. Use LMTools to clear your previous setup first, then restart license setup wizard to re-configure your license.
4. Shut down the lmgrd process and check that lmgrd or agileesofd processes are no longer running. Restart the license server.
5. Stop lmgrd via kill pid (UNIX) withough -9 argument or stop the lmgrd process through the Windows Task Manager or Windows Service.
6. Close all processes that are reading the logfile.
License Requested:  mom_obj
License path:  C:\Program Files\Keysight\license.lic
--- ERROR ---------------------------------------------------------------------
License not available
该怎么办啊,我已经重装过一次了,不想再重装了。
特别麻烦,很有可能要重装系统。
发表于 2020-2-12 08:39:32 | 显示全部楼层
你好,请问你这个问题解决了吗?我的也是FEM不能运行
GMT+8, 2025-12-17 17:23 , Processed in 0.013841 second(s), 4 queries , Gzip On, Redis On.
