查看: 4797|回复: 3
[求助] The bulk-drain junction current exceeds `imax'
发表于 2017-5-4 16:23:41 | 显示全部楼层 |阅读模式
Warning from spectre at time = 1.12551 ms during transient analysis `tran'.
    I60.M13: The bulk-drain junction current exceeds `imax'.
Notice from spectre at time = 1.12551 ms during transient analysis `tran'.
    I60.M13: The bulk-drain junction current no longer exceeds `imax'.
Warning from spectre at time = 1.14117 ms during transient analysis `tran'.
Notice from spectre at time = 1.14117 ms during transient analysis `tran'.
Warning from spectre at time = 1.20611 ms during transient analysis `tran'.
Notice from spectre at time = 1.20611 ms during transient analysis `tran'.
Warning from spectre at time = 1.21913 ms during transient analysis `tran'.
Notice from spectre at time = 1.21913 ms during transient analysis `tran'.
    tran: time = 1.249 ms    (4.99 %), step = 11.84 ns    (47.3 u%)
Further occurrences of this warning will be suppressed.
Warning from spectre at time = 1.38841 ms during transient analysis `tran'.
Notice from spectre at time = 1.38841 ms during transient analysis `tran'.
        Further occurrences of this notice will be suppressed.
从前面的提醒到最后的提醒消失,这个影响仿真吗?需不需要管呢?
发表于 2017-5-11 00:59:18 | 显示全部楼层
THAN K YOUI VERY MUCH
发表于 2017-5-12 22:14:12 | 显示全部楼层
看看是不是结击穿了
发表于 2017-5-13 03:09:23 | 显示全部楼层
查一下Vdb,如果很大,或者使PN结正偏,那肯定不行
GMT+8, 2025-12-16 15:01 , Processed in 0.021576 second(s), 5 queries , Gzip On, Redis On.
