查看: 4541|回复: 6
hspice 2015安装破解问题求救
发表于 2017-4-11 21:59:04 | 显示全部楼层 |阅读模式
各位前辈
本人安装hspice 半个月都没成功,希望大家能帮我看看问题究竟出在哪
安装包:hspice_vK-2015.06
lisence管理:SCL_11.7
用的破解工具NewSynopsysLicmaker
按照网上教程破解,并且sssverify  lisence 成功,但lmgrd -c  lisence时候老是报错不能启动,如下:
6:44:42 (snpslmd)
6:44:42 (snpslmd) Licenses are case sensitive for TE_CATS
6:44:42 (snpslmd)
6:44:42 (snpslmd) EXTERNAL FILTERS are OFF
6:44:42 (lmgrd) snpslmd using TCP-port 59594
6:44:42 (snpslmd) Serving features for the following vendor names:
snpslmd  ACAD  adalmd  anagram  arcd  archprod  avantd  CADABRA  chrysalisd  cowared  EPIC  eved  everest  extremed  hscd  innologd  ISE-TCADd  knights  la_dmon  leda  magma  metasoftd  mwflexd  nassd  nsysnvs  numeritchd  pdld  riod  saber_dmn  sandwork  sclmgrd  sigmacd  slat  snpsOEM1  snpsOEM2  snpsOEM3  snpsOEM4  snslmgrd  ssilmd  synforad  synopsysd  synplctyd  TAVEREN  TE_CATS  tmald  vastlmd  vcsd
04/11/2017 06:44:44 (snpslmd) ------------------------------------------------------------------
04/11/2017 06:44:44 (snpslmd) Checking the integrity of the license file....
04/11/2017 06:44:44 (snpslmd) Valid SSS feature found.
04/11/2017 06:44:44 (snpslmd) The feature is needed to enable the other keys in your license file.
04/11/2017 06:44:44 (snpslmd) Licensed to mammoth//ZWT 2006
04/11/2017 06:44:44 (snpslmd) Siteid: 19688, Server Hostid: 000C29B8F4A9, Issued on: 12/28/2012
求各位大神帮忙看看吧,谢谢了
 楼主| 发表于 2017-4-12 10:10:01 | 显示全部楼层
没人帮忙一下吗
发表于 2017-4-12 10:50:20 | 显示全部楼层
看來你的feature只有SSS,沒有hspice要用的feature如hspice!
 楼主| 发表于 2017-4-12 11:11:39 | 显示全部楼层
回复 3# mhleu
   谢谢,那要怎么获得呢,坛子里有吗
发表于 2017-4-13 14:26:51 | 显示全部楼层
论坛里有很多的
发表于 2017-4-17 10:14:46 | 显示全部楼层
SCL_11.7 低了  我用的scl11.9  2014 可以跑起来  15 没试过  你换个scl 高版本试试
发表于 2023-8-27 16:26:45 | 显示全部楼层
lic: The desired vendor daemon is down.  Check the lmgrd log file, or try lmreread. Feature:         lic: Using FLEXlm license files:   lic: 28000@work-eda   lic: Unable to checkout (hspice) 请问这种问题怎么解决,我是随便下载的一个虚拟机
GMT+8, 2025-12-29 16:41 , Processed in 0.016278 second(s), 4 queries , Gzip On, Redis On.
