楼主: 要你命3000
找软件的Feature方法!
 楼主| 发表于 2020-6-28 07:40:38 | 显示全部楼层
rp2004 发表于 2020-6-28 04:22
You said"1. Use the strings command to export all text information of the software (remember to find ...
strings is a linux command. If you on windows platform, maybe you should use https://docs.microsoft.com/en-us/sysinternals/downloads/strings
This method is try to extract all strings from the binary file.
So, if you have a binary file, for exmaple "aaa.exe", then you can type following command:
   strings aaa.exe > 1.txt
Then you can use a text editor, for example, notepad, open this 1.txt file. Use the text search function of the text editor....
发表于 2020-6-29 16:07:06 | 显示全部楼层
牛逼啊,看看
发表于 2020-6-30 19:13:07 | 显示全部楼层
小白来学习一下1111111111111111
发表于 2020-6-30 20:05:20 | 显示全部楼层
这个feature难道不是AE应该告诉的么
发表于 2020-7-1 14:05:33 | 显示全部楼层
怎么办
发表于 2020-7-1 14:33:35 | 显示全部楼层
看看这个,最近刚好有一个报错。
发表于 2020-7-2 14:03:32 | 显示全部楼层
see             it
发表于 2020-7-2 14:25:54 | 显示全部楼层
学习中,希望你说的方法有用
发表于 2020-7-3 21:51:28 来自手机 | 显示全部楼层
看看
发表于 2020-7-6 14:01:42 | 显示全部楼层
好奇如何查找Feature
GMT+8, 2025-12-30 08:57 , Processed in 0.019016 second(s), 6 queries , Gzip On, Redis On.
