查看: 4226|回复: 14
Antenna Magus 2016.0.1 Professional Working - No Time Limit
发表于 2017-3-4 10:02:11 | 显示全部楼层 |阅读模式
Hi all,
I have succeeded in getting Antenna Magus to work without a time limit. You will only be able to update it to 2016.0.1 version. You cannot update to 2016.1 or 2016.2 version. But remember like I said earlier, it has no time limit, which means you can use it for more than 3 or more years.
If you happen to be interested, send me an email on fast.forever24@gmail.com so that we can talk more.
发表于 2017-3-4 12:30:06 | 显示全部楼层
根本没必要永久的,现在软件更新速度快。过两年就新版本出来了。永久的意义不大。
 楼主| 发表于 2017-3-11 03:51:29 | 显示全部楼层
回复 2# gxlly
@gxlly, do you have any working license file? I do not think so. There is no much difference between the older versions of antenna magus and the newer versions. It is better to have a working older version (in our case 2016.0.1 or 2016.1) for 4 years or more than not to have any working version at all. For instance the major difference between versions 2016.0.1 and 2016.1 is 7 antennas. You can see that from the pictures I would upload below.
I have also been able to make Antenna Magus 2016.1 Professional work with any time limit. For more information and discussion you can contact me on fast.forever24@gmail.com.
发表于 2017-3-11 08:29:46 | 显示全部楼层
it can update to 2016.2 with license,maybe more.And from 5.1 to 2016.2 only two years.I only know it is update very fast.anyone,who use it who select it.I only know patch file is not stable.
发表于 2017-3-11 09:21:51 | 显示全部楼层
回复 3# MarcelMan
我5.5的时候买的,现在升级到2016.2了,而且免费延长,但现在估计不行了。对比破解文件我觉得:1.首先license能够一直升级,至少2016.2还能用,可能将来也可以,破解的肯定不行,可以用新的为啥不用,多学习一点不是坏事;
2.其次我不喜欢破解文件的,因为不知道计算结果是不是正确,你说的是永久我也无从验证是不是永久,至少2年后验证才知道;
3.最后,如果您能直接拿出来分享最好,那我肯定支持,如果收费那就算了,这东西查不了多少钱还是能支付得起。
不过还是谢谢您的努力和回复,当然青菜萝卜各有所爱,几百元的事用来学习一下还是值得的,期待您的分享。
发表于 2017-3-13 10:57:31 | 显示全部楼层
回复 5# gxlly
   你买正版的?多少钱?
发表于 2017-3-13 11:15:31 | 显示全部楼层
回复 6# wncom
   和谐的。
发表于 2017-3-13 22:11:26 | 显示全部楼层
回复 7# gxlly
   分享一下可以不?david098@126.com
发表于 2017-3-13 22:40:19 | 显示全部楼层
回复  gxlly
   分享一下可以不?
david098 发表于 2017-3-13 22:11
分享也没用,不像5.3的绑定MAC或硬盘信息,除了绑定信息其他格式和5.3的一样,我试着找了,找不出来,这个不知道绑定什么。。
发表于 2017-3-14 08:06:02 | 显示全部楼层
楼主来卖钱的
GMT+8, 2025-9-13 22:39 , Processed in 0.024544 second(s), 6 queries , Gzip On, Redis On.
