查看: 3258|回复: 3
VCS 2016.6运行不起来,请教
发表于 2017-2-15 00:30:23 | 显示全部楼层 |阅读模式
界面都能正常启动,但编译出错,错误提示如下,求高手指导
This program is proprietary and confidential information of Synopsys Inc.
and may be used and disclosed only as authorized in a license agreement
controlling such use and disclosure.
Error-[UASFLEXLM] License checkout failure
  Failed to checkout a license and the FlexLM licensing library returned an
  error code of '-1'.
Error-[LICENSE_CHECKOUT_FAIL] Failed to checkout license
  License checkout failed for feature 'VHDL-Event-Sim' of version '2016.06'.
  Please contact VCS customer support to obtain a license and verify that
  environment variable LM_LICENSE_FILE is set correctly.
Error-[SIM_NEED_LICENSE] License failure
  VCS MX simulator requires licenses for VHDL-Event-Sim
  Please contact VCS customer support to attain a license or correct your
  license variable setting.
make: *** [run] Error 255
发表于 2017-2-15 15:32:24 | 显示全部楼层
No Features listed.
 楼主| 发表于 2017-2-15 19:44:56 | 显示全部楼层
回复 2# phoenixson
   检查过了,这个feature在license文件里面是有的啊
发表于 2017-2-16 10:03:28 | 显示全部楼层
回复 3# seth0001
    如果是floating mode,你可以看看log, 是否有这些feature checkout checkin的记录
GMT+8, 2025-12-21 21:13 , Processed in 0.013925 second(s), 3 queries , Gzip On, Redis On.
