查看: 2106|回复: 1
[求助] 小女子跪求specman 中的“test” 命令
发表于 2017-2-8 14:34:23 | 显示全部楼层 |阅读模式
specman 里load test_write_read.e 文件后,执行test如下:
specman test_write_read> test
Doing setup ...
Generating the test with IntelliGen using seed 1929919524...
Starting the test ...
Running the test ...
   *** Warning: ERR_TE_NOSIM: No simulator is attached.
Therefore, '@sim' and 'delay' temporal expressions will never occur.
To change the severity, type:
set notify -severity=<new-severity-level> ERR_TE_NOSIM
To see possible severity levels use 'set notify -help'
Use the "tick" command to advance the time
请问如何解决上述问题?
 楼主| 发表于 2017-2-8 15:03:30 | 显示全部楼层
请各位给看看,在线等,谢谢
GMT+8, 2025-12-16 09:10 , Processed in 0.288299 second(s), 4 queries , Gzip On, Redis On.
