查看: 20383|回复: 51
Mentor crack/patch ver. 11.10 (2016)
发表于 2016-12-23 04:04:55 | 显示全部楼层 |阅读模式
MentorKG.EFA.11.10.0.rar (512.93 KB , 下载次数: 1123 )
the Step 1. AS Administrator the Run Command prompt.
the Step 2. the In the Enter Command prompt:
                     . MentroKG -patch <installation_directory>
. the Step 3. To the Save generated license.txt
the Step 4. The MGLS_LICENSE_FILE to the Set Point to License .txt.
the Step 5. The ENJOY !!
发表于 2016-12-23 06:34:11 | 显示全部楼层
Is there any way to apply this MentorKG to Linux releases?
发表于 2016-12-23 07:20:55 | 显示全部楼层
thanks
发表于 2016-12-23 07:35:04 | 显示全部楼层
頂一下!感謝大大無私分享
发表于 2016-12-23 08:29:31 | 显示全部楼层
Ding, thanks
发表于 2016-12-23 08:35:49 | 显示全部楼层
does it work with calibre 2016?
发表于 2016-12-23 10:02:25 | 显示全部楼层
please give me this file !!
     pkginfo  (dirctory files)
     mgls.dll file
 楼主| 发表于 2016-12-23 14:44:56 | 显示全部楼层
回复 2# judung
   install wine and run on terminal:           wine MentorKG.exe -patch <path_to_install>
 楼主| 发表于 2016-12-23 14:46:26 | 显示全部楼层
回复 6# chris2013
   yes it works with everything.
发表于 2016-12-23 19:51:13 | 显示全部楼层
感谢大侠分享!!!!!
GMT+8, 2025-12-27 06:31 , Processed in 0.020683 second(s), 4 queries , Gzip On, Redis On.
