查看: 2088|回复: 0
cadence 616+unbutu16.04LTS安装问题
发表于 2016-12-16 23:35:56 | 显示全部楼层 |阅读模式
按照这个帖子的步骤http://bbs.eetop.cn/viewthread.php?tid=606269,安装完后发现仿真不了。大牛看看是什么原因?
Delete psf data in /home/nan/simulation/mos/spectre/schematic/psf.
generate netlist...
Loading seCore.cxt
Begin Incremental Netlisting Dec 16 07:32:14 2016
End netlisting Dec 16 07:32:14 2016
Loading monte.cxt
The netlist is up to date.
Time taken to compare the design with netlist:   0.0s
      ...successful.
compose simulator input file...
      ...successful.
start simulator if needed...
      ...successful.
Loading paraplot.cxt
ERROR (ADE-3036): Errors encountered during simulation. The simulator run log has not been generated.
        Possible cause could be an invalid command line option for the version of the simulator
        you are running. Choose Setup->Environment and verify that the command line options
        specified in the userCmdLineOption field are supported for the simulator.
        Alternatively, run the simulator standalone using the runSimulation file in the netlist
        directory to know the exact cause of the error.
GMT+8, 2025-10-13 11:37 , Processed in 0.016780 second(s), 4 queries , Gzip On, Redis On.
