查看: 3535|回复: 3
vcs 编译问题
发表于 2016-12-4 14:29:39 | 显示全部楼层 |阅读模式
各位大侠,小弟的Makefile内容如下:
vcs_comp=vlogan +v2k $(inc_path) -nc -work work
comp-vcs:
        $(vcs_comp) $(src_path)/cnt.v
        $(vcs_comp) $(src_path)/test.v
vcs: comp-vcs
        vcs  work.test -o ./simv_mx -l comp.log
        #vcs +neg_tchk -negdelay -notice -debug work.test -o ./simv_mx -l comp.log
run-vcs: vcs
        ./simv_max
vcs-clean:
        @if [ -e work ]; then \
                rm -rf work; \
        fi
        @if [ -e comp.log ]; then \
                rm -rf comp.log; \
        fi
编译两个.v文件。
再执行make vcs时,出现一下问题:
vlogan +v2k +incdir+../src -nc -work work ../src/cnt.v
Parsing design file '../src/cnt.v'
vlogan +v2k +incdir+../src -nc -work work ../src/test.v
Parsing design file '../src/test.v'
                         Chronologic VCS (TM)
            Version C-2009.06 -- Mon Dec  5 14:03:53 2016
               Copyright (c) 1991-2008 by Synopsys Inc.
                         ALL RIGHTS RESERVED
This program is proprietary and confidential information of Synopsys Inc.
and may be used and disclosed only as authorized in a license agreement
controlling such use and disclosure.
Error-[SFCOR] Source file cannot be opened
  Source file "work.test" cannot be opened for reading due to 'No such file or
  directory'.
  Please fix above issue and compile again.
1 error
CPU time: .342 seconds to compile
make: *** [vcs] Error 255
各位大神如何解决?谢谢
发表于 2016-12-8 11:05:23 | 显示全部楼层
 楼主| 发表于 2017-6-11 11:00:02 | 显示全部楼层
不是找不到文件,是无法创建work库
 楼主| 发表于 2017-6-11 11:02:28 | 显示全部楼层
需要在本地建立一个synopsys_sim.setup文件,内容如下:
WORK > DEFAULT
DEFAULT : ./work
好像就行了
GMT+8, 2025-12-26 16:42 , Processed in 0.018795 second(s), 3 queries , Gzip On, Redis On.
