查看: 47365|回复: 79
Help, questa 10.4/10.5 crack
发表于 2016-8-26 23:49:22 | 显示全部楼层 |阅读模式
Has someone cracked questa 10.4 or 10.5 on LINUX?
The modelsim 10.4 crack works on questa 10.4 win64 version, but on
linux I get the "Unable to checkout a viewer license necessary for use of the ModelSim graphical user interface.
Vsim is closing.
" error?
Questa 10.3_1 is working fine on linux. Maybe the problem is that 10.4 uses flexlm 11.11or something?
Can someone provide a link to a valid linux crack for questa 10.4 or 10.5 or post a tutorial
on how to do it?
发表于 2016-8-27 22:59:02 | 显示全部楼层
MentorKG_patch.rar (509.98 KB , 下载次数: 586 )
MentorKG -patch <install_dir>
on linux install wine first, then
wine MentorKG.exe -patch <path-to-install>
 楼主| 发表于 2016-8-30 02:24:17 | 显示全部楼层
When I run your patch on linux I get this error:
"err:seh:setup_exception_record stack overflow 1104 bytes in thread 0044 eip 7bc4050f esp..."
When I run other MentorKG that I downloaded it generates a license properly.
With other licenses I get this:
error
error
Questa 10.3.1 works on linux, I have been able to crack questa 10.4 on windows, but on linux
with 10.4 I get the "msimviewer" error.
Can anyone confirm that there is a working crack for 10.4 linux?
发表于 2016-8-31 03:47:53 | 显示全部楼层
Unfortunately, I can only confirm that MentorKG is no longer generating proper licenses for the recent Mentor tools
(if you already have cracked it for windows maybe the same type of patch will fix it also on Linux...)
 楼主| 发表于 2016-8-31 18:14:13 | 显示全部楼层
Thanks for the reply. I can confirm that this crack works for Questa 10.4 64-bit on Win7 64-bit:
http://bbs.eetop.cn/thread-488297-1-1.html
But on linux I can't seem to find a working crack. I can confirm that there is a working Questa 10.3 version for linux, but NOT 10.4 or 10.5.
If someone has a solution please post it here.
发表于 2016-9-3 21:19:25 | 显示全部楼层
Thank for sharing this confirmation, I finding that
 楼主| 发表于 2016-9-12 23:06:05 | 显示全部楼层
If someone knows a working linux crack for 10.4, please post it here
 楼主| 发表于 2016-9-25 20:11:53 | 显示全部楼层
Solved finally!!! This crack provided by johnsonzhxun works for Questasim 10.5, running on Linux Mint 64-bit.
破解10.5可用破解10.2的工具和方法, 唯一的区别在于run sfk时,请用
./sfk rep -yes -pat -bin /5589E557565381ECD00000008B5508/31C0C357565381ECD00000008B5508/ -bin /5589E557565381ECD8000000E8000000005B81C3/33C0C357565381ECD8000000E8000000005B81C3/ -bin /41574989FF415641554154554889CD534489C3/33C0C389FF415641554154554889CD534489C3/ -dir .
发表于 2016-10-2 16:52:17 | 显示全部楼层
Can you please upload last release?
发表于 2016-12-10 12:24:41 | 显示全部楼层
回复 8# evilpascaltwin
10.3c linux 64 bit也適用
感謝
GMT+8, 2025-12-26 19:25 , Processed in 0.030407 second(s), 4 queries , Gzip On, Redis On.
