查看: 5194|回复: 4
[讨论] LVS 的global问题
发表于 2016-5-17 11:42:58 | 显示全部楼层 |阅读模式
各位大侠:
请问lvs runset文件中下面这句话是什么意思?
LVS SPICE OVERRIDE GLOBALS YES
谢谢
发表于 2016-5-17 14:34:43 | 显示全部楼层
同问.求回答
发表于 2016-5-17 16:55:01 | 显示全部楼层
应该是忽视GLOBAL的意思吧,没用过,不是很肯定
发表于 2016-5-24 09:50:59 | 显示全部楼层
• NO
Specifies that global signals apply to all subcircuit pins throughout their internal hierarchies
and cannot be overridden except through the LVS Spice Prefer Pins YES specification
statement. This is the default behavior.
• YES
Specifies that an assignment of a signal to a global pin in a subcircuit call has the effect of
overriding the respective global signal in the referenced subcircuit and in the entire subhierarchy
below the subcircuit.
发表于 2021-11-5 13:56:24 | 显示全部楼层
MARK MARK
GMT+8, 2025-11-29 03:54 , Processed in 0.017813 second(s), 3 queries , Gzip On, Redis On.
