查看: 2574|回复: 3
[求助] 77GHz Layout
发表于 2016-4-26 10:19:47 | 显示全部楼层 |阅读模式
电感的SRF如何提高?有什么有效措施吗?
发表于 2016-4-28 00:46:15 | 显示全部楼层
There are some basic approaches that help you to increase the SRF.
- Reduce the inductor area. Try to use the minimum line width available in your technology
- Make the windings closer to each other. Use the minimum that your DRC allows
- Dont use a ground metal plane under the inductor. This increases the losses but does not generate a bigger capacitance from the inductor to the metal plane.
Reducing the inductor size will typically result in the desired SRF. Try that.
Hope that helps.
BR
发表于 2016-4-28 00:48:46 | 显示全部楼层
Try to reduce the inductor area. If you need a big inductance value, use lines with minimum width to increase the inductance per unit length. That typically will allow you to control the SRF very good.
Hope that helps.
发表于 2016-4-28 16:49:31 | 显示全部楼层
路过,没有做过,帮你顶下
回复 1# 恶魔法则1
GMT+8, 2025-12-30 11:34 , Processed in 0.026566 second(s), 7 queries , Gzip On, Redis On.
