查看: 5066|回复: 4
[求助] 关于Cadence中pnoise modulated的问题
发表于 2016-4-20 09:54:19 | 显示全部楼层 |阅读模式
最近在对自己设计的LC VCO进行仿真,进行到pnoise modulated的时候有些疑问,在pnoise modulated中有AM和PM的选项,不是很清楚它们各自的意义,除此之外,pnoise仿真和pnoise modulated仿真各自有什么区别吗?希望大神能够回答一下~
发表于 2016-4-20 11:45:36 | 显示全部楼层
You can separate the Amplitude Modulation (AM) and Phase Modulation (PM)
components of the total noise by calculating components in-phase (AM
component) and in quadrature (PM component) with the carrier by using PAC
and BPN PHASENOISE analysis. The output and measure syntax separates
AM/PM noise.
■ If you use the NLP algorithm (METHOD=0) default, HSPICE RF calculates
only the phase noise component.
■ If you use either the PAC algorithm (METHOD=1) or the BPN algorithm
(METHOD=2), HSPICE RF adds both the phase and amplitude noise
components together to show the total noise at the output.
PM[NOISE] Measures the phase modulation noise from the specified first to the
second IFB frequency points (when .OPTION PHASENOISEAMPM=1)
AM[NOISE] Measures the amplitude modulation noise from the specified first to the
Example : These AM/PM sample commands find the amplitude modulation (AM)
and phase modulation (PM) noise across the specified input frequency
range.
.measure PHASENOISE amp1 AM phnoise from=100k to 400k
.measure PHASENOISE pmp1 PM phnoise from=10meg to=30meg
 楼主| 发表于 2016-4-20 19:16:15 | 显示全部楼层
回复 2# edafolks
    I got it ! Thank you soooooo much !
 楼主| 发表于 2016-4-20 19:35:49 | 显示全部楼层
回复 2# edafolks
    but I can't understand the BPN phasenoise analysis,can you spell its full name  for me ,please?
发表于 2016-8-16 16:24:51 | 显示全部楼层
who know it ???!
GMT+8, 2025-12-13 18:18 , Processed in 0.026490 second(s), 7 queries , Gzip On, Redis On.
