查看: 2464|回复: 2
[招聘] 浦东/浦西某大型美资公司+Digital design engineer(senior-staff)
发表于 2016-4-1 10:49:30 | 显示全部楼层 |阅读模式
1.产品:ddr
地点:漕河泾开发区
Digital Design Engineer
Job Description
-Work with analog/digital ASIC design team for new product development;
-Design, implementation, and verification of digital in mixed-signal ICs;
-Perform backend digital design (logic synthesis, formal check, define design constraints for place & route, perform timing closure, DFT);
-Support system, test & product team with chip debugging, failure analysis, characterizations and product release efforts.
Qualification Requirements
-Master degree or above in EE or related field;
-At least 5 years experience in digital design;
-Have rich experience at high speed digital design;
- Projects tape out experience with 65nm process, 40nm or 28nm preferred;
-Experience as project leader is a plus;
-Good knowledge in semi-conductor and transistor level;
-Good language and communication skills in English for both spoken and written;
-Highly organized and self motivated;
-Ability to work well with teammates (locally or remotely) in a fast-paced professional environment.
2.产品:IP
地点:浦东
Senior Digital design engineer
Position Description:
Deliver/implement DDR/HBM IP. The engineer should be able to act as a strong team member and contributor. Exercise judgment within generally defined practices and policies.
Specific duties include:
1.Proficiency in logic design, simulation, synthesis, STA and testing
2.Proficiency in Verilog and its simulation environment
3.Good knowledge of IC design
4.At least two years’ experience driving complex IC development projects, excellent communication skills and the uncanny ability to both lead and contribute in a cooperative team environment.
Position Requirements:
1. Essential Qualifications: Must have BS degree with 4+ years of applicable experience, MS degree with 2+ years of applicable experience in electrical engineering, microelectronics, comparable engineering science or solid state physics.
2. Essential that the individual demonstrates strong communication, verbal and written.
Requires good communication skills in English.
Desirable Qualifications:
1.Will have demonstrated successful completion of 5+ design projects as an individual contributor
2.Familiar with JEDEC-DDR/HBM, DFI and AMBA protocols and have DDR project design experience
联系方式:chloe-zhang@kthr.com;微信号:13916933764
发表于 2016-4-1 14:48:13 | 显示全部楼层
micron
发表于 2016-4-2 19:27:59 | 显示全部楼层
漕河泾还能有谁
GMT+8, 2025-12-23 09:03 , Processed in 0.104256 second(s), 7 queries , Gzip On, Redis On.
