查看: 5332|回复: 1
高悬赏求助】求quartus 15.1 (update2)能支持EP4CE10编译的license
发表于 2016-3-26 17:21:40 | 显示全部楼层 |阅读模式
悬赏100资产未解决
高悬赏求quartus 15.1 (update2)能支持cyclone 的EP4CE10 FPGA编译的license或破解办法。
用论坛有人分享的quartus15.1 编译 EP4C10程序时,显示如下错误:
Info
(20030): Parallel compilation is enabled and will use 4 of the 4 processors detected
Warning
(292000): FLEXlm software error: Invalid (inconsistent) license key.  The license key and data for the feature do not match.  This usually happens when a license file has been altered. Feature:       quartus License path:  D:\FPGA\altera\15.1\licenses\license.dat; FlexNet Licensing error:-8,523 For further information, refer to the FlexNet Licensing documentation, available at "www.flexerasoftware.com"..
Error
(119013): Current license file does not support the EP4CE10F17C8 device. Go to the Self-Service Licensing Center on the Altera website to manage your licenses (https://mysupport.altera.com/AlteraLicensing/license/index.html).
Error: Quartus Prime Fitter was unsuccessful. 1 error, 1 warning
Error: Peak virtual memory: 850 megabytes
Error: Processing ended: Sat Mar 26 17:26:42 2016
Error: Elapsed time: 00:00:01
Error: Total CPU time (on all processors): 00:00:01
Error
(293001): Quartus Prime Full Compilation was unsuccessful. 3 errors, 1 warning
发表于 2016-12-21 21:27:00 | 显示全部楼层
lic 没有破解好
GMT+8, 2025-12-25 16:31 , Processed in 0.018414 second(s), 5 queries , Gzip On, Redis On.
