查看: 2037|回复: 0
删改贴申请
发表于 2016-1-28 18:42:41 | 显示全部楼层 |阅读模式
http://bbs.eetop.cn/thread-592772-1-1.html 这个贴子不会在二楼发图片着急又发了新贴http://bbs.eetop.cn/viewthread.php?tid=592775&extra=
和下面这些Layer mapping file name                  : ./smic065/TF/TF_Cds/SmicDR15R_VTTF_0065_LG_V1.10_0R/SmicDR15R_VTMP_0065_LG_V1.10_0R.map
Double pattern map file                  : (null)
Rename cell file name                    : (null)
Child cell depth                         : 20
Skip reference lib cells                 : false
Text height width ratio                  : 1.000000
Text width                               : 0.000000
Flatten contact                          : false
Flatten contact array                    : false
Contact prefix                           : $$
Output notch                             : false
Output gap                               : false
Output fill                              : true
Output outdated fill                     : true
Output instance name as property         : false
Output geometry property                 : false
Strip backslash from instance net names  : false
Long name length                         : 255
Keep data type                           : true
By layer number                          :
Output compressed OASIS                  : false
Output compressed GDSII                  : false
Output pin as text                       : true
Output pin as geometry                   : true
Pin name magnitude                       : 1.000000
Net name magnitude                       : 1.000000
Rotate pin text by access direction      : false
Output net as text                       : false
Output net as property                   : 1
Output net as plex                       : false
Output odd pin                           : false
Design intent struct name                : (null)
Critical name list                       : (null)
Design intent layer mapping              : (null)
With original data                       : true
Output design intent data                : false
Rename multiple LEF foreign cell names   : false
GMT+8, 2025-11-5 06:29 , Processed in 0.052902 second(s), 8 queries , Gzip On, Redis On.
