查看: 2488|回复: 3
[招聘] 上海外资芯片设计公司急招数字前端Logic设计工程师(Sr. to Staff)
发表于 2016-1-9 17:27:16 | 显示全部楼层 |阅读模式
有兴趣的可以发简历到email: david-chen@kthr.com,谢谢
Logic Design Engineer
Responsibilities:
LogicDesign Engineer is working on cutting-edge Digital and Mixed-signal IP developmentfor worldwide clients, including High Speed Serial Links,Protocols, Memory Interface, etc. By employing the industry leading tools,state of the art methodology, and innovative semiconductor leading technologiesranging from 32nm to 14nm and beyond, you will be participating in the front-endlogic design or mixed signal design.
Requirements:
1. ME/EE/CS orbackground in related areas.
2. Research and/ordevelopment experience in one or more of the following areas:
Logic Designon the basis of the target system specification
Mixed-signalmodel design on advanced technologies
Proficiencyin programming and/or scripting languages is a plus
Knowledge onProtocols, High Speed Serdes or DDR is a plus
3. Experience in oneor more of the following application domains, is a plus
Highperformance computing system, processor, chipset and ASICs
High end communication,networking, mobile and data center applications
Digitalsignal processing, sensor and Internet of Things
Otheremerging IT technology and industry areas
4. Good English skills,communication skills, and willingness to work with a global team. Skill inother languages is a plus.
5. Good learningcompetency, self-motivated, and ability to work in diverse areas in a flexible anddynamic environment.
 楼主| 发表于 2016-1-13 13:57:29 | 显示全部楼层
自己顶一下!
 楼主| 发表于 2016-1-19 11:14:07 | 显示全部楼层
 楼主| 发表于 2016-1-20 11:05:20 | 显示全部楼层
自己顶一下!
GMT+8, 2025-12-16 07:13 , Processed in 0.017264 second(s), 6 queries , Gzip On, Redis On.
